Help with passing emission in IL
Discussion in 'Gen 2 Prius Main Forum' started by Naskaf1, Sep 4, 2025.
  1. Naskaf1
    Naskaf1 Junior Member
    Detroit
    Hello, I have a gen 2 prius w/ 300,000 miles on it. Car runs beautifully. I was due for an emissions test but got a check engine light. We only got the catalytic converter replaced w/ an aftermarket one. The check engine light went away, it has not appeared in over 2 months. However, using an OBD2 scanner my car isnt ready for emissions. I have driving the car way over 5K miles since changing the converter. People have mentioned a drive cycle but I've literally driven the car so much by now.
    Evaporative system is reported as : not ready
    Oxygen sensor: not ready
    what do I do about this?
    52,854
    any trouble codes? what scanner?
  3. Naskaf1
    Detroit
    No check engine light. Using car-scanner app with veepak
  4. BiomedO1
    BiomedO1 Senior Member
    4,596
    2,411
    Left Coast
    You need to get the car properly scanned because something is keeping the emissions system from completing it's checks - most likely the aftermarket CAT. Any Prius aware scanner should be able to tell you what's hanging-up the diagnostic system - It's stuck in a retry/recheck cycle.
  5. Naskaf1
    Detroit
    With an aftermarket catalytic converter would I not get any codes?
  6. BiomedO1
    4,596
    2,411
    Left Coast
    You need to complete an emission test cycle to trip another emission code. As I stated earlier, it's stuck in a retest cycle - a good scanner will tell you which test it's stuck on.
    I'm just guessing it's that aftermarket CAT. What codes were you getting BEFORE you replaced the CAT?
  7. Brian1954
    Brian1954 Senior Member
    2,679
    1,071
    South Central PA, USA
    The OP stated the tests that are not complete in post #1.
  8. Naskaf1
    Detroit
    P0420
  9. BiomedO1
    4,596
    2,411
    Left Coast
    did you check the upstream and downstream sensors for proper function before replacing the CAT; since your getting O2 sensor not ready. Are the sensors plugged in and fully operational? the proper scan tool will tell you this and give you readouts. ditto with the evap 'not ready'. valve not toggling, high or low leak rate.
    #9 BiomedO1, Sep 5, 2025
  10. pasadena_commut
    pasadena_commut Senior Member
    3,064
    951
    Southern California
    Is the aftermarket catalytic converter an approved model? Not sure if that is a thing in IL but it is in CA. In CA it will never pass without an approved part, no matter what the OBD2 reads.
