Help with poor city milage
Discussion in 'Gen 3 Prius Fuel Economy' started by Leehljp, Nov 12, 2011.
  1. Leehljp
    Leehljp Junior Member
    Tunica MS
    I am getting Poor city gas milage as compared to what I am reading on different posts here. Can someone tell me if my situation is unusual or what? I average 30 - 35 mpg in town.
    Here is what I know:
    • I have read the manual(s) (while waiting in doctors offices for long delayed appointments.)
    • I am not lead footed but I have read that faster acceleration to driving speed is often better than slow slow acceleration. And have tried both, One week one method, the next week the other method. Both seem to give close to the same overall results.
    • Tires at 42 / 40 PSI.
    • Long trips (interstate and local between cities) I average 44 - 49 mpg. Mostly flat or mild hills.
    • Use EV when I can but even in my small town, if I accelerate too slow (to stay in EV), other's road rage mentality makes me quickly get out of the EV and into ECO.
    • Read lots of posts here and nothing that I have read so far deals with this issue - that I can recognize. (I am an American who has lived in Japan for the past 25 years and sometimes semantics throws me :rolleyes: )
    I have had my 2010 Prius IV for 2 months. It had 33,000 miles and now has 37.000.
    IN TOWN SITUATION - and probably my problem:
    My in-town driving for my small home town is basically 2 to 4 blocks, then a stop sign, so lots of stops in a short distance. Longest straight without a stop is 1/2 mile. IS this the cause?
    Even in Memphis in town, I get about 32 - 35 mpg. Lots of stop lights and turns, but a little longer distances between turns and stops.
    I reset my "trip" meter when in town/city situations to check these MPGs - by the dash, which I know is not totally accurate but reasonably so. It is usually over an hour or so of driving in those places.
    I love the 32 - 35 MPG in town compared to the 14 - 16 of my other vehicle, but I was wondering how some of you get 50MPG? Do I need to move to a larger city with less 4-way stops and more synchronized stop lights? ;) Seriously, is this normal MPG for tons of stops and starts?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The one thing that caught my eye was the use of "EV" mode. Don't use it for regular driving. At most, use it for moving in/out of garage for washing, etc. The engine has to run to replenish the battery anyway you look at it and it does it more efficiently during regular driving as opposed to idling..
  3. Gary Otto
    Gary Otto Member
    123
    Silver Springs, FL
    I have noticed that going thru town at slower speeds (30 to 40 mph) has yielded the highest mileage. Stop and go lowers it quite a bit. The longer you are stopped, the lower your mileage. Sitting while waiting for a stop light is most likely going to be factored in as a 0 mpg.
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    As I recall, Tunica has mostly stop signs (no way to 'time' a stop sign) and some uncoordinated traffic signals on US-61. (no way to match the pattern)
    It is small enough to drive anywhere and not warm up the engine. Dead flat.
    25 MPH in town, 45 MPH on US-61 (I get my best 'in town mileage at 35 MPH, but 45 is better than 25, for me)
  6. fuzzy1
    10,603
    Never mind the distance between stop signs, what is your total trip distance per trip segment or engine warm-up cycle?
    From a map it appears that Tunica and North Tunica combined are less than 2 miles end-to-end, not enough to fully warm the engine. If this is true, in-town MPG will be horrible in any car.
    I figure that engine warmup costs me roughly the same fuel as driving about two miles with an already-warmed engine. If your trips are less than two miles (i.e. 4 miles worth of fuel), the only reason you are getting above half the EPA city rating, i.e. above 25 mpg, is that the engine is not fully warming.
  7. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    I remember watching the warm-up phase in my Taurus. It was pointless turning on the heater until it was complete. You could clearly tell when it was complete. The engine RPM would suddenly drop. Just think what the MPG would have been during those first few minutes of driving. We were clueless back then... when automakers didn't include an efficiency gauge. Having such detailed information in Prius sure is an eye-opener.
  8. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Stopping is wasted momentum, and it takes energy to build it back up. So the more you stop, the lower your mpg.
    Completely inaccurate. Once the engine is warmed, it cycles off when not needed such as when waiting at a stop light. This is not 0miles per gallon it is undefined miles per gallon. 0miles/0gallons = undefined. Undefined on the Prius is 99.9mpg or 0.0l/100km depending on geographic region.
    The exception is if you have a high drain on the HV battery while sitting there like high AC usage. Then you are lowering your mpg not now, but later when the engine kicks in to recharge.
    +1
  9. Leehljp
    Tunica MS
    I have only used EV mode about 5 or 6 times in a couple of months - to see what was happening. Each time I tried it, the battery showed to be only one or two bars from full at the least.
    Thanks for this, I will keep it out of EV.
  10. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    The OP still needs to answer the questionnaire.
  11. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Sitting at a stop light (with the Engine OFF) has no effect on mpg. Sitting with the engine on while warming-up does have an effect. Very short trips, like you do, will result in 30-35 mpg. This is still 15-20 mpg better than any other gas powered car.
  12. Leehljp
    Tunica MS
    I am visiting with my daughter in Springfiled MO and family is calling for my attention.
    I will reply in full to the answers in 24 hours after I get back home.
    The Short answer, as mentioned in posts above is found in the PDF file:
    11) Short Trips: You will almost immediately notice that your first 5-minute bar on the consumption screen will be in the range of 25-35 MPG most of the time. To warm the engine and catalytic converter, the car will use extra fuel. Therefore, short trips are a mileage killer.
    I know that there is more to it and I will answer those questions and respond to each of you when I get some time in the next 24 hours. THANK YOU for your help! And glad to see one fellow from the MS Delta here! :D
  13. walter Lee
    1,126
    376
    Maryland
    General Guidelines
    1) Set the 2010 Prius to "ECO" mode and not "EV" Avoid depending on the electric drive.
    2) Your tires might not be Low Rolling Resistant tire(LRR). If you donot have LRR tires then you should consider replacing them with LRR tires.
    3) Take your foot off the accelerator earlier before stopping so that the Prius will slows down and coast to under 14 mph before applying the brakes. This will likely require a lower top speed than you are achieving now. This is best done when there are few cars on the road or when you are in a multilane road that allows others to pass your vehicle if they get upset that you are driving too slow.
    4) Redesign your commute trip/route to favor traffic lights over stop signs. Avoid both if you can. With traffic lights you can sometime synch yourself with the green lights and not have to stop - saving kinetic energy will increase your MPG - you cannot do this with a stop sign. In hypermiling this is called Driving without Brakes (DWB)
    5) Avoid hard accelerations ( HSI in power bar) - when possible do gentle accelerations (HSI in ECO bar just under the "ECO" capsule). When possible synch accelerations on a downhill grade. Avoid accelerating as much as possible on uphill grades.
    6) Speed and Fuel Efficiency go hand-in-hand. For city driving - the most fuel efficient speed range is from 25mph to 35 mph (75 to 65 mpg). For highway driving - the most fuel efficient speed rang is from 45mph to 55 mph (65 mpg). The Prius fuel efficiency declines as its speed increases from 60mph (56 mpg) to 75 mph (48 mpg).
    7) The Prius mileage can be low for the first 30 minutes in driving (especially in stop and go driving, when the outside temperatures falls below 65F) because the Prius engine does not warm up as quickly to its optimum temperature. After the Prius is driven longer than 60 minutes/12 miles, its fuel efficiency increases and its is very easy to get over the EPA rating. There are four techniques use to increase FE (all are covered in Cleanmpg.com) by assisting the Prius ICE to achieve its optimum operating temperature:
    A. Grill blocking (for the 3rd generation Prius is means blocking the lower grill air intake when the outside temps go lower than 60F).
    B. Mini Warm up Pulse & Glide Cycles - at startup of a trip or route with a cold engine (ICE) you press the accelerator so that the HSI is always a little pass middle of the "ECO" bar but not pass the "ECO" capsule (this forces the ICE on and puts it into an fuel efficient 1.5KW operating range) and start accelerating until the Prius reaches its designated top speed of 10 mph - then you let go of the accelerator so that the HSI indicator is at the leftmost edge of the "ECO" bar but not in the "CHG" (regenerative recharging) bar so that the Prius is coasting via power created mostly by the ICE (and using very little electrical power). When the Prius speed begins to drop, you repeat this procedure over and over again but with a higher top speeds, e.g. 15mph to 20 mph for the second cycle, 25mph to 35 mph the third cycle, and soforth until the Prius is at its desired top speed. This avoids using the battery and accelerates warming up the ICE to its optimum temperature (coolant temperature = 180F). If you are in a traffic jam that is longer than 15 minutes - use this technique instead of using your electric motors to inch along in traffic to avoid draining your HV battery ( so the Prius can avoid needing to recharge it HV battery pack because of extended electric drive usage).
    C. Install an engine block heater and heatup the engine before starting the prius. The ROI doesn't seem be significant unless you're driving in the Northern/colder regions like Canada, Minnesota, or Alaska. For Mississippi and Maryland - it's mainly for MPG bragging rights :D
    D. Combine multiple smaller trips together such that any stop over does not allow the gasoline engine to cool down too much ( say less than 15 minutes per stop over). Hence, the fuel efficiency of each successive trip improves because it has the advantage/benefit of an engine that is already warmed up.;)
    hope this helps
    Walter Lee,
    Cleanmpg.com "HyperDrive 1" mileage log
    2010 Toyota Prius III, Blue Ribbon/Dark Grey, Oem Floormats
    Yokohama Avid S33, 50psi/48psi
    ScangaugeII (FWT, SoC, RPM, GPH)
    100% grill blocking
    Odeometer 17000 miles, 60.7 mpg overall
    Best tank 727 miles/10.25gallons/70.9mpg
    (calculated, summertime)
    Worst tank 428 miles/08.18gallons/52.3mpg
    (calculated, wintertime)
    Best Commute Trip (16 miles, downhill, 70F degrees, 50/48 psi
    tires, no rain/snow, no grill blocking, no AC/heat/defrost,
    w/ warmed up engine) = 93 mpg (AVG ScangaugeII, 89 mpg PriusMFD).
