Help with this...only 2 blue bars on battery (pic)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by imfinallywright, Jun 24, 2015.
  1. imfinallywright
    imfinallywright New Member
    South Central IL
    Looked at and test drove another prius today...07 with 145k. It looks to be in great shape with fairly good and up to date service records all maintained at the dealer. We have driven a few others at dealers, this one was a personal sale. We actually met at a Toyota lot as it is her dealer...when we drove it as soon as we got in it, this is a pic of what the bars looked like only two blue lit up. We didn't drive it long as my husband was a little concerned right off the bat with that but as we were driving it, there did up being about 3 or so bars and they turned purple. I have only seen the bars when we test drove to be all green and fairly high up there with only 1 or 2 ever missing. He is convinced that the hybrid batter must be going bad due to these colors and short stack of bars. Please assure me one way or the other? Or...at least give me some advice? I am thinking of maybe asking her to do a battery check at the dealer. The thing is...she is in IN and we are in IL so we drove over 2.5 hours just to look at the car and don't want to make the trip back unless for sure buying it. Let me know what you think of this...please. Thanks! I am spending way too many hours on here with you guys, you have already been soooo helpful in knowing what to look for and questions to ask! :)
  2. Patrick Wong
    18,210
    6,517
    The traction battery state of charge gauge has the following number of bars and colors:
    8 green bars ~ 80% state of charge
    7 green bars
    6 blue bars
    5 blue bars
    4 blue bars
    3 blue bars
    2 purple or pink bars
    1 purple or pink bars ~ 40% state of charge
    When the air conditioner is running in hot summer weather and the car is being driven in stop & go traffic it is normal for the SOC gauge to show 1 or 2 bars. Otherwise when the car is being driven at speed the gauge will normally show 4-6 blue bars.
    7 or 8 green bars usually happen only when the car is being driven downhill on mountainous terrain.
    Good luck with your purchase decision.
    GrumpyCabbie and imfinallywright like this.
  3. vskid3
    vskid3 Active Member
    773
    228
    If the seller was sitting in the car with it on waiting for you, the hybrid battery would drain to that point before the engine will kick on to maintain the charge. It should get back up to the normal 5-6 bars within a couple miles of driving.
    imfinallywright likes this.
  4. JC91006
    16,936
    8,647
    sooner or later, they all go bad (batteries)
  5. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    when in doubt buy a new car, you are already at the dealer
  6. imfinallywright
    South Central IL
    Thanks so much, everyone! I know they all go bad eventually but if I can avoid one thAt already us I'm ahead I would love to purchase new...however I wouldn't love to be in debt. To purchase new, I could come home with a brand new chevy spark. :/ don't think I didn't look at it though, because I did. ;)
  7. Kevin06prius
    Kevin06prius Junior Member
    45
    Westchester
    Add the price of a hybrid battery installed to what you are paying for the car. If you think that is still a good deal then go for it. From what I have been told you cannot check the life of the battery so you will not know if it is about to fail. A used car with 145k miles can need a few things. I just did a tune up on mine with spark plugs and serpentine belt and other basic things at 160k. Headlight bulbs are expensive and they may be gone without you knowing it. I bought mine from the dealer with 140k miles last year and everything was working fine. And hour into the drive home a headlight was out and the door lock acuator stopped working. Acuator is over $500 installed. Headlight is between $50 and $300 depending on what you get and where you get it from. To this day I still have headlight issues and told it could be the ballast. So buying a car of that age and miles will cost you something in the near future. It's better to buy a new Corolla or Yaris for less money or a new Prius if you can afford one of you don't want surprises. If you are willing to spend $1,000 plus the cost of a hybrid battery within a year then you should be fine. I believe a Prius C is under $20k new.
  8. Beachbummm
    1,160
    392
    chevy spark is Daewoo like the Yugo's of the 1990's but much worse
  9. bisco
    52,855
    spark gets some good write ups, maybe a payoff involved, idk.
  10. prius_2007
    prius_2007 New Member
    tn
    what is the asking price?
  11. imfinallywright
    South Central IL
    Sorry, just saw this. Was asking $7200 just dropped to $6800
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Unfortunately you can't tell a lot from the initial battery state, because even a brand new battery will go low like that if the Prius is left parked and in ready mode for a while. The real test is how widely and how rapidly the state of charge varies once you are driving, particularly once the engine gets up to normal temperature.
    It's probably a bit difficult if you haven't done a lot of driving in other Prius's, so that you have something to compare it to. However if you can take it for a slightly longer drive, especially with some hills, it would be more telling.
    #12 uart, Jun 30, 2015
  13. stylinnnn
    stylinnnn Junior Member
    36
    san diego
    weak mileage for both..whoa
  14. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    The battery bar means nothing to how good the battery is. If you are really serious about buying a Prius you should get a Bluetooth code reader so you can see the battery state as you are driving it.
  15. bisco
    52,855
    check the last post date before replying.:)
    Raytheeagle likes this.
  16. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Just bought a 2006, 134k miles, with a supposed rebuilt battery.
    I'm curious, do you ever get all green bars? My top bar never turns green (always white) is that normal, or is the battery not working 100% ?
  17. bisco
    52,855
    congrats and welcome!
    you can get all green under certain circumstances. down a looooonnnngggg hill, or certain highway driving.
    give it some time. if it never goes all green, you just have to live with it until the battery fails
    how are your average mpg's?
  18. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Go up to Lake Tahoe. On the way back you should get all green bars at least once.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Just take it west out of the Caldecott tunnel and it’ll hit green bars;).
    Our 2010 would do that frequently(y).
    Skibob likes this.
