Help! Won't start with red padlock light on dash
Discussion in 'Gen 3 Prius Main Forum' started by Steelerfan2018, Jul 24, 2021.
  1. Steelerfan2018
    103
    42
    Pittsburgh
    Hello all,
    A bit of an emergency, I need help.
    Went to get into my car this morning and the key fob did not work to open the car, I had to use the key. Both of my key fobs have new batteries.
    I tried starting the car with no success - it basically does nothing except the red light with the padlock symbol. I have never seen this before.
    Could this be a problem with a 12v battery? I have recently had issues with losing MPG (see my other recent thread).
    Any and all help appreciated!
    Rob
    privilege likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    On the Gen 3, I think you should be able to hold the fob up to the power button and it will detect the RFID chip inside to allow starting the car. Its the backup mode in case the wireless stops working.
  3. Steelerfan2018
    103
    42
    Pittsburgh
    Fixed - it was the 12v battery. Swapped out the battery this morning and all is well.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Glad that's what it was. I would have suggested that since that's what happens with an almost dead 12V.
    The red padlock light simply means that the immobilizer system is active because the car is off. You might not have seen it, but it's always blinking if the car is off.
