Helpppppp loosing bhps??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MeGuinness, Jan 4, 2017.
  1. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Any ideas from were to start checking?
  2. Tideland Prius
    16,679
    Probably a 1.5 litre if it's the same system as our Prius c.
  3. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Yes, apparently the Yaris isn't available as hybrid in a lot of countries. The Yaris hybrid uses the same powertrain as the second generation Prius so I guess it's baiscally the same as the Prius c. It also has similar dimensions.
    And yes, conventional dash. There's also a Toyota Auris which is a bit larger with the 3rd gen Prius drivetrain, also with conventional dash. The Auris hybrid TS (stationwagon) is quite popular because it offers more interior space than the Prius III or IV.
  4. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Guys I noticed something....While engine is on I tried removing the oil cap....Once I unscrewed alot of air is coming out from there to the point I could not screw it back , engine changes noise too when pulling oil dip stick in and out .
    PVC valve stuck ??? Can I drive with dip stick out in the meantime to release pressure?
  5. Mendel Leisk
    42,343
    I'm not sure how much pressure there should be, but at 190K miles changing the PCV valve wouldn't hurt. NutzAboutBolts has a video on getting to it, pinned in third gen maintenance section.
  6. MeGuinness
    MeGuinness Member
    217
    78
    UK
    I will try to clean it once I'm back home , looking online they seem £££££ here in UK !!!!wondering if ok to drive with deep stick halfway out ??
  7. Mendel Leisk
    42,343
    What is happening to engine sound when you loosen oil fill cap? Seems to be smoothing out, sounds better?
    I've a strong hunch you have some Scottish blood, lol? I would spring for a new pcv valve with that mileage, but that could my mom's (dutch) side coming out. Some of my dad's ancestors were from the Shetlands, hence the name. :)
    My son and I did the pcv valve replacement on his Civic. It was tougher than the Prius I think: Shop Manual instruction was to first remove the intake manifold. I invested in a $40 ratcheting box wrench with extended reach, and was able to avoid this. It was impossible to put a regular ratcheting wrench on the valve, too bulky.
  8. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Yes it smooth down .....I have unscrewed the cap and pulled out the stick half way in the meantime, I hope the pcv is the reason of the rough engine behaviour
  9. Mendel Leisk
    42,343
    I'd advise to take a short test drive with your venting solution, see if it's spraying much. I accidentally left oil fill cap off once (on another car) and it was a bit of a mess. Also: the fumes were getting sucked into the cabin a bit I think. :oops:
  10. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Quick update.... The engine is running smoother and the mpgs that have been down constantly between 39 and 43 for the past couple of weeks now is instantly up to 55mpgs
    ,...Just keeping fingers crossed that is just the pcv . Got to drive for work till tomorrow evening so I will keep an eye on the cap
  11. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Took the valve out ....190k of crap in there ,cleaned as much I could inside out,now refitting,
    Anything else while I'm there with everything out to check? 1483898155756.jpg 1483898159405.jpg
    Raytheeagle and Mendel Leisk like this.
  12. Mendel Leisk
    42,343
    That's pretty knackered! You're just reusing then? Did you check the price for a new one? With our Honda it was around $25 (Can $). It was such a production getting to it, and considering it's a one time thing.
    That said, assuming you've soaked/cleaned the interior the same as the outside, probably good as new.
  13. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Is about 40$ in UK unless I can use another car valve that fits ?
  14. Mendel Leisk
    42,343
    You're running circles around me, financially. When my son and I did the pcv valve on his civic, it was $25 for the valve, and $40+ for the swivelling/ratcheting/extra-long box wrench, to be able to extract the valve without taking off the intake manifold, lol.
  15. MeGuinness
    MeGuinness Member
    217
    78
    UK
    If I could only find to remove that crap from the valves wall lol .... safely
    Cleaned the egr valve pipe.... Again...And again....Lost count.
    Refitting....Nearly there .....Let's hope
  16. MeGuinness
    MeGuinness Member
    217
    78
    UK
  17. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    How was it checking prior to install? If it was not checking well, the problem will persist.
    There does appear to be a bit of oil passing through. Have you tried anything to help like high mileage oil, engine treatments, etc?
  18. MeGuinness
    MeGuinness Member
    217
    78
    UK
    No treatment no ,what would be the symptoms if checking well or not ? Pushing from the bottom it feels free ,same from top ,I did shake it and it was rattling.....
    Raytheeagle likes this.
  19. Mendel Leisk
    42,343
    The throttle body bolts to the intake manifold, correct? Just curious, do you remove intake manifold with throttle body still attached?
    And there are coolant hoses on the throttle body?? Just leave them connected?
  20. MeGuinness
    MeGuinness Member
    217
    78
    UK
    No I took Everything appart one by one
    Yes I left the coolant pipes attached to the throttle body
