Helpppppp loosing bhps??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MeGuinness, Jan 4, 2017.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    If it is freely rattling when you shake it. With the amount of buildup you had, even at $40 to replace it, I would have splurged and taken it out of the equation.
    Is that the original oil cap on the engine? Mine has the 0W-20 stamp on it. Something happen to yours in the past?
    Might be worth a compression test as the seals and rings maybe letting too much through.
  2. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Did the dealer find anything wrong or did you resolve your battery issues? Has the code returned?
  3. MeGuinness
    MeGuinness Member
    217
    78
    UK
    If the engine is running and I pull the pcv pipe from the manifold what should i look for ? Air coming out I assume ?
  4. MeGuinness
    MeGuinness Member
    217
    78
    UK
    They could not run the scan system because it need about 400 miles from the last cleared code to run the test or it would fail.....Don't ask Wth it means lol
    Raytheeagle likes this.
  5. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    How long do you have until you have to pass the inspection? I would focus on logging the 400 miles and ensuring the permanent code clears to get the inspection pass. Or has the code returned and that is the reason for the current investigation?
  6. MeGuinness
    MeGuinness Member
    217
    78
    UK
    The code asnt returned from when I been driving with the oil cap half unscrewed and the mpgs have come back to normal, I notice like drag break when driving and lift off the gas pedal while engine is on when driving with the cap fully closed, as soon I open the cap my mpgs go up to about betwen 57 and 60 and the drag break is gone and car drives smoth
  7. MeGuinness
    MeGuinness Member
    217
    78
    UK
    So there are 2 rubber pipes attached to the manifold,one is the pcv pipe ,the other goes to a electric valve ?
  8. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The PCV valve is a one-way valve, so you test by blowing air through it and it should open and pass air in one direction and not the other. It should also rattle if you hold it in your hand and shake it.
  9. Rebound
    3,996
    2,645
    Portland, OR
    It may be that your rings are going bad. You might want to try a compression test. I'd clean out the PCV and EGR, but if your EGR is also very oily, the clean out is somewhat temporary because the failing rings will continue to fail. A compression test should let you assess the quality of your rings and valves. In this test, you screw a meter into each spark plug hole and measure the compressed pressure when you crank the engine. One school of thought is repair the bad rings or valves, the other school of thought is clean the PCV/EGR until the engine completely dies, then replace it with a used motor.
    I'm only speculating and I'm a home mechanic with limited experience, so don't get all excited and buy a new car or a new engine just because of what some guy on the Internet said. Cars with bad rings/valves can often last another 40,000 mi or more.
