Here is a question I have yet to see...
Discussion in 'Gen 2 Prius Technical Discussion' started by BillMelder, May 2, 2022.
  1. BillMelder
    BillMelder Junior Member
    24
    Tennessee
    So I've searched the forums for about two hours and haven't found anything regarding this.
    So last weekend I was replacing the battery modules (cells) on my 2007 Toyota Prius Hybird Battery. I happened to strip the post on one of the modules. So I decided it would be a great idea to tap n die the post right there next to the other cells. Well the the tap and die tool hit the post of one of the other cells and a spark ignited. With that said... is there anything I should be looking out for on the battery to see if anything shorted out? I just want to make sure I check before I put the battery back in the car.
    Thank you!
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    Just use a voltmeter to (carefully) check the voltages of the affected battery modules. Really, electrically I expect things to be fine. A Prius battery is designed to output 150-200 Amps for some seconds- if there was a sustained arc that would probably burn away most of the connecting stud. A few sparks ain't nothing.
    What happened is a demonstration of why HV safety practices gotta be followed.
    anothertckt and Yosarian like this.
  3. BillMelder
    24
    Tennessee
    Thank you so much for responding. I work on maybe one of these batteries every week. I agree, I need to demonstrate better safety practices. I do wear gloves but I wasn't using the best judgement that day. I figured it would be a pain to take everything apart again... Hindsight I should have.
    Again Thank you!
    I'm doing a stereo and headlight upgrade I plan to share soon!
