Hesitation and no codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pdaddy, Feb 10, 2021.
  1. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Have you observed any radiator coolant loss in the reservoir?
  2. Pdaddy
    Pdaddy Member
    160
    49
    Nope. All levels are normal under the hood.
    SM-G960U ?
  3. johnnychimpo
    johnnychimpo Active Member
    522
    112
    Monterey
    in the end what was the issue.
  4. Pdaddy
    Pdaddy Member
    160
    49
    Not fixed yet. Been too cold to work on the car.
    SM-G960U ?
  5. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    Maybe try "Chevron Techron" additive and an "Italian Tune-up"!?
  6. Pdaddy
    Pdaddy Member
    160
    49
    I took the air intake manifold off intending to potentially replace it as the dealer would have done. However I think the valves are messed up on #4 piston. They don't look seated compared to the other valves, and look like they are dropped down. I did get intermittent misfire or pending misfire on 1 and 4 but only one time during all the rumbling drives.
    Does the car need a valve job? Could this have been caused from rough idle due to air intake obstruction? Or happened on its own? At 245K miles should I consider paying for this (no idea about cost)? As to my level of skill I have only replaced rings on an old motorcycle and otherwise only replaced common failing parts.
    Appreciate insight from those who have dealt with this..... Screenshot_20210228-200533_Gallery.jpg Piston4%20both%20valves.jpg
    SM-G960U ?
  7. Pdaddy
    Pdaddy Member
    160
    49
    SM-G960U ?
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Can you use the copy and paste feature to put the images inline?
    Copy the image using Control-C, and then Paste the image using Control-V, makes it easy to put images in the reply box.
    It appears you're using facespace images or something, which don't show up for me.
  9. ASRDogman
    ASRDogman Senior Member
    8,015
    4,071
    Some valves will be open because the piston is not at it's highest point.
    Only 2 at a time will be, the others will be opposite.
  10. Pdaddy
    Pdaddy Member
    160
    49
    Shouldn't pistons 1 and 4 be synchronized and valves will be similar or is there enough variability with valve timing that this not the case?
    SM-G960U ?
  11. ASRDogman
    8,015
    4,071
    One is on the compression stroke the other is on the exhaust stroke, I believe.
    Rotate the engine by hand and you can see them moving....
    Pdaddy likes this.
  12. ChapmanF
    18,934
    It's not about timing variability, it's that pistons 1 and 4 move up and down together, but they are half a cycle apart in firing order. If 1 is up on its compression stroke now, 4 will be on its compression stroke the next time it is up.
    Having them fire together wouldn't make sense.
    Pdaddy likes this.
  13. Pdaddy
    Pdaddy Member
    160
    49
    So I just need to turn the bolt on what looks like a pully on the passenger side of the engine to turn it by hand?
    SM-G960U ?
    ASRDogman likes this.
  14. ChapmanF
    18,934
    That's how it's done.
    Pdaddy likes this.
  15. Pdaddy
    Pdaddy Member
    160
    49
    I replaced the air intake manifold and problem is solved. The old one was still pretty caked up despite an attempt to clean it last summer (in my defense the focus was on the EGR cooler which took me a week to clean at the same time). Thanks for the advice!
    SM-G960U ?
    Mendel Leisk and SFO like this.
  16. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    All 4 cylinder cycles are staggered. If cylinder 1 fires its plug then 180* later cylinder 3 will fire, 180*- cylinder 4, 180* then cylinder 2.
    Cylinders 1 and 4 are companion cylinders- each is 360* apart / out of sync. When 1 is at TDC compression stroke, 4 is at TDC exhaust stroke and vice versa. 2 and 3 are also companions- 360* apart from each other but staggered 180* from 1 and 4.
    Every 4 stroke engine design will complete one full cycle of each cylinder every 720* (2 revolutions). 180* for intake stroke, 180* for compression stroke, 180* for the power or expansion stroke, 180* for the exhaust stroke. Then begin again.
    Pdaddy likes this.
