Hesitation at junctions
Discussion in 'Gen 2 Prius Main Forum' started by cjcj1949, Dec 16, 2019.
  1. cjcj1949
    cjcj1949 Junior Member
    uk
    I have a 2007 uk Prius. It has been fine since I bought it in 2011. Recently, possibly after its last service it occasionaly hesitates when pulling away from a standstill. I've connected a wifi obd sender and looked at the fault codes. U0100 and U0293 are reported. Is this a well known problem?
    Thanks
    Chris John
  2. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Not sure if that OBD2 device is hybrid compatible, as DTC U0100 has three (3) related subcodes (INFs). Knowing which subcode(s) can help identify the problem, and possibly help in solving/repairing it quicker.
    Go online and buy a 'mini-vci' cable (u$20), that will offer you access to the same software the dealer uses (techstream).
    Graeme1949 likes this.
  3. fomenter
    fomenter Junior Member
    michigan
    When you buy the cable, does the software come on a CD that they provide. Thanks
  4. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Generally, yes. Or the seller will provide a link to download from.
    One can do a simple search and also find it online.
  5. Duug
    Duug Junior Member
    West of Nowhere
    Try cleaning the fuel injectors.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    For the life of me I cannot understand why posters can’t list the mileage on there car.
    Like all of us on this G2 forum the car is at the vintage where the hybrid battery is starting to go south or worse.
    Watch the hybrid charging behavior on the mfd. if it’s tanking to purple bars real quick like at a light or fast food waiting in line that’s stage 1 of failure.
    The g2 is an under powered go kart without good power participation from the hybrid battery,
  7. cjcj1949
    uk
    The car has been serviced by Toyota. It has done 50000 miles. The hybrid battery has been checked at the last service by Toyota. It goes from green to blue and blue to green. I will ask the garage when the fuel injectors were last cleaned. It is still under an extended warranty and booked in for January. It has also stopped going wrong. I thought there might be a problem with the engine starting. It is difficult to tell when the engine is running as it ticks over smoothly at low revs. The main problem now is that fault has gone for now. Thanks for all the thoughts.
