hesitation on acceleration even on a new battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tariq87, May 26, 2019.
  1. Tariq87
    Tariq87 Member
    87
    28
    jordan
    It's clean... shin bright like diamond...
    52,878
    maybe you need an engine. do a compression test.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    We are overcomplicating the hell out of this. I challenge ANY of you to run your AC until you have two purple bars on the MFD. Now, with 2 purple bars, try to pull out into busy traffic. Good luck and I hope you don't get crushed.
    This is pretty much normal conditions for when the battery is at that state of charge. If you have any type of monitoring app. like hybrid assistant or techstream, it will display the discharge current limit and charge current limit currently active on the battery. Check it out. High temps limit it, low temps limit it, low SOC limits it.
    52,878
    but, but, didn't you see post #6?:p
    Raytheeagle likes this.
  5. Mendel Leisk
    42,364
    2nd gen might be a little pokier at two bars than 3rd gen (OP has 2010)? Still, I agree: my 2010 feels a little "passive aggresive" with two bars.
    Editorial: the hybrid battery charge status doesn't change color on 3rd gen, just "cathode ray tube" green, all the time.
  6. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Also..something i forget about...also loud knocking sound coming from the engine head while its on 2 bars
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And how much drained OUT before you re-filled it ??
    If you are trying to say NONE, meaning that you ran it dry........
    You don't need to worry about a little hesitation because it will soon be totally DEAD.
  8. Tariq87
    Tariq87 Member
    87
    28
    jordan
    1 liter or little bit more will be drained each time
  9. Tariq87
    Tariq87 Member
    87
    28
    jordan
    What do you mean by totally dead?
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    About a half liter remains in the filter so you are trying to run your engine on a half liter of oil.
    Guaranteed massive engine failure fairly soon.
    You do know that you are supposed to keep the correct of amount of oil in the engine all the time.......right ??
    :eek:
    This does NOT work like the gas tank where you run it until it's about empty and then fill it up.
  11. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Sure i know... im tired of it man...
  12. bisco
    52,878
    aren't we all...
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    The ignore user function of Prius Chat is an amazing thing(y).
  14. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Dears
    The car stopped hesitation by it self .. i think she was need sometime to let the computer back to his normal functionality with the new battery..its now like a new one..
    bisco and Mendel Leisk like this.
