Hey Everyone , needing help with my 2006
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Stephen Scheurich, Mar 15, 2021.
  1. Stephen Scheurich
    Stephen Scheurich New Member
    Direct me to where I can get some advice on my 2006, engine light came on saying it's the throttle position sensor. Thanks
    Stephen
  2. PriusCamper
    PriusCamper Senior Member
    11,095
    4,515
    Pacific Northwest, USA
    The device that read the error code might not be compatible because throttle position sensor, which is rarely a problem comes up often on incompatible code readers. You need a reader that's specific to hybrids, like Dr. Prius app via one of these devices: Hybrid battery diagnostic and repair tool for Toyota and Lexus
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Throttle positioner is pretty common error on this forum.
    the throttle body is fly by wire and the butterfly motor is having trouble turning the throttle butterfly because it’s gunked up.
    use the search forum link up top and search throttle body hundreds of posts about it how to clean and lube it.
    Btw your in California be aware cat theft is a huge problem there with your car. Hundreds of posts about that too it’s a bitch because the cats are ungodly expensive and there all back ordered.
    Search. Stolen cat.
    Search YouTube video “ Prius stolen”
  4. dolj
    dolj Senior Member
    7,648
    3,859
    Wellington, New Zealand
    As PriusCamper said the what is reported as a problem with the throttle position sensor is an incorrect report which is a pretty common error on this forum.
    Get the codes read again with a Prius capable reader and post the actual code, like P1121 for example.
