Hey I'm brand new here. Need some help!
Discussion in 'Gen 2 Prius Main Forum' started by Gat, Nov 26, 2018.
  1. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    Maybe the good folk over in the Gen 3 forums maybe more familiar with this scenario and can help you.
    SFO, PriusCamper and Skibob like this.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Exactly. It could be something that happens to gen 3 Prius and not gen 2 Prius. Being in the correct forum might help.
  3. Jakemathews
    Jakemathews New Member
    22
    Buena park ca
    So new to this lol can you possibly put a link to that page i need to get to that way i can go directly and post on there. Thanks alot guys appreciate it!
    Raytheeagle and bisco like this.
  4. Jakemathews
    22
    Buena park ca
    I looked around the wiring and may have noticed somthing that looks like possibaly “rat poop” on top of the inverter. Is it possibal the code wont go away because the rat chewed a wire and that wire is the readon it stays on constantly? Just thinking as a long shot
  5. ChapmanF
    19,027
    This is the weirdest story I've heard all year.
    There are around 28 ECUs in a Gen 3 Prius, depending on the option level.
    Do you have access to a laptop with Techstream, or to a person with a laptop with Techstream? Somebody other than this smog inspection place or hybrid shop with their "hybrid battery scanner"?
    I would like to see what an actual Techstream health check says for this car. With screenshots.
  6. dolj
    dolj Senior Member
    8,646
    4,398
    #66 dolj, Aug 16, 2019
    Skibob likes this.
  7. Jakemathews
    22
    Buena park ca
  8. Jakemathews
    22
    Buena park ca
    A buddy of mine has tech-stream we connected it to the prius and tried to erase the code but it wont even let us erase it at all. Once we erase it immediately its back right away because it was never even erased to begin with.
    Thinking that it might be a hassle to keep bugging my buddy so i should probably get my own techstream if you can recommend which tech stream is good for the 2012 prius please provide a link if you can that i can purchase on a budget
  9. dolj
    dolj Senior Member
    8,646
    4,398
    I don't know why that didn't insert correctly, but try the link in post #66 now.
    It is not that it is not erasing, it is. It is just that the fault exists and resets immediately after you clear it.
    #69 dolj, Aug 16, 2019
    PriusCamper likes this.
  10. Jakemathews
    22
    Buena park ca
    Right i understand what your saying its just mind boggling at this point really want to figure it out as ive never seen anything like this before
  11. Jakemathews
    22
    Buena park ca
    Just tried it and same thing
  12. dolj
    dolj Senior Member
    8,646
    4,398
    Works for me. But as I can't edit your post, the link you quoted is still broken. Perhaps you could go in and edit your post and replace all the text with a period. Then go ahead and try the link in post #66
  13. Jakemathews
    22
    Buena park ca
    Works now thank you!!!
