Hey kids! New acquisition.
Discussion in 'Gen 3 Prius Main Forum' started by Ianmeister, Sep 16, 2020.
  1. Ianmeister
    Ianmeister Active Member
    316
    320
    Meridian Idaho
    got it!!
    Data Daedalus, SFO and Mendel Leisk like this.
  2. Ianmeister
    316
    320
    Meridian Idaho
    Woo hoo! Got the time if cover off and all the bolts first try! Man there sure were a lot of bolts! 077F675D-3EB0-4C43-8421-E5717D48D4C7.jpeg E1087AE7-55AB-4BE0-8A3C-D751F43DD92E.jpeg
    Raytheeagle, Mendel Leisk and SFO like this.
  3. Ianmeister
    316
    320
    Meridian Idaho
    Getting there! 162C3028-8348-48C8-B966-BD95C5A39A46.jpeg watch out for the hidden bolt in the cam box! (upper left corner) there’s always a hidden f**king bolt!!
    Mendel Leisk, Ed Beaty and SFO like this.
  4. Ianmeister
    316
    320
    Meridian Idaho
    Ok. Head is out. 28F99B2A-0213-4C02-B901-25C089AD940B.jpeg E6CC71C3-7520-4778-8E68-8BBC191292AC.jpeg AFB973EC-D97C-42F0-A0EF-0C9FB8A93F7E.jpeg
  5. Ianmeister
    316
    320
    Meridian Idaho
    Here’s a better image of the head gasket 84969731-EBD3-4A37-B493-3936A7BE83C0.jpeg
    SFO likes this.
  6. Ianmeister
    316
    320
    Meridian Idaho
    Here’s one showing how thick the crap in the intake manifold is. I ran a little screwdriver across it to show how deep it is. I guess airflow is overrated! C5C15074-C480-4AF4-AF00-B28CE4E211D4.jpeg
    SFO likes this.
  7. ETC(SS)
    7,587
  8. Mendel Leisk
    42,386
    Head gasket failed between cyl one and two?
    Other areas on the verge of failure.
    And the clogging of the intake manifold EGR passages: progressively more clogged towards cyl one end?
    Kinda nuts, but I'm envious, looks like fun.
  9. Ianmeister
    316
    320
    Meridian Idaho
    You are correct. It's pretty clear that the coolant was running into number2. That one is steam cleaned, the valves look different on that cylinder only and the exhaust port looks different too.
    Also I did find a little caramel looking sludge under the valve cover.
    The front main seal was leaking and the bottom of the engine was sludged up real nice too. Looks like the PO was using thick conventional oil to deal with oil loss. I got a full gasket kit so I'm replacing everything I can reasonably get to.
    For now, I need a nap!
    Mendel Leisk, SFO and ILuvMyPriusToo like this.
  10. Mendel Leisk
    42,386
    #70 Mendel Leisk, Oct 1, 2020
    ASRDogman likes this.
  11. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Even if the head is still flat/straight, you need to replace the valve guide seals!
    NOW is the easiest time to do it, while the head is off.
  12. Ianmeister
    316
    320
    Meridian Idaho
    Yes. It's at the machinenshop now. They start with a $50 pressure test to make sure it's not cracked. From there they test to see if the valves still hold pressure. If its a yes they swap out the valve seals, clean it up and send me on my way for 150. If it needs a full valve job then maybe $350 total. They were thankful I had the correct Toyota valve seals to give them.
    For now I'm going after the struts, shocks and Hybrid cooling fan.
    Strangely the cooling fan had very little dust. My gen 2 looked like a dryer lint trap. I wonder if maybe this has is on its second battery?
  13. Ianmeister
    316
    320
    Meridian Idaho
    Woo hoo! The head passed and only needs seals and a good cleaning. I’ll get it back today!
  14. ASRDogman
    8,070
    4,092
    That's good! You got to it before he head warped. That's always good.
  15. Ianmeister
    316
    320
    Meridian Idaho
    And she’s back! The verdict is no cracks and the valves are in perfect condition with no measurable wear! So new seals, a good cleaning, a quick resurface and I’m home with it for a total of $212.50. Not bad I’d say. What amazes me is that after 227k miles there is no appreciable wear. Most cars historically would be clapped out hoopties or junked by now. This one is just getting started! C2751AAD-71B6-4730-8829-B963E5064B61.jpeg
  16. Gliderguy
    Gliderguy Junior Member
    46
    Prescott Valley, AZ
    I went down this very road about a year ago.
    Looking at that head gasket I say it was leaking coolant into 3 of 4 cylinders. I replaced my head gasket at 175k and only had one part of the gasket where the black sealant was worn away.
    A neat trick for the rough running on startup is to carefully vent the pressure off of the coolant overflow tank every time you shut the engine off. A good head gasket will only pressurize the coolant tank a little. A blown one will sound like you are opening a hot 2 liter of soda every time. releasing the pressure this way will keep coolant from being pushed into the cylinder while the car sits, and minimize the rough starts. Some old school mechanics would intentionally leave the radiator or overflow cap loose to prevent pressure from building up specifically to solve this problem so a car could limp along for a little while longer if needed. Couldnt tell from the pictures, did you rotate the engine and make sure all pistons came up to the same level to rule out bent connecting rods?
    Mine had almost no visible wear at 175k. I replaced the water pump too. There is some discussion that the head gasket sealing material was not really compatible with the kind of coolant Toyota uses, and they seem to fail pretty reliably in the range that both you and I experienced. I have yet to hear of a single re-do needed after a head gasket change, I think the newer or aftermarket gaskets must use a more robust material.
    The whole rest of my car that has 192k on it now is so tight I cannot believe it. I think it will go until the insulation falls off the wires or some plastic parts get too brittle and start falling apart wholesale.
    Change the transmission fluid if you have not. It doesnt cost much and if you want a few more hundred thousand miles, it would be a good idea.
  17. Gliderguy
    46
    Prescott Valley, AZ
    Watch closely for the timing chain to jump when you go to release the tensioner, I had to try three times, the first two times it jumped a tooth. I don't think you could double check yourself too much on this particular step before you button everything back up. Everything else was very straight forward. If you got it apart you will get it back together. I took a weekend to get mine apart, got the head work done through the week, and put it back together the following week. That was about 17,000 miles ago and all is still well.
  18. Mendel Leisk
    42,386
    @Ianmeister i'm curious if you locked the cams when removing? Not sure how crucial it is, but I believe it makes reassemble easier. There's a trick of putting a tri-fold strips of shop towel in one cam shaft journal, then gently retightening, so they hold positions.
  19. Ianmeister
    316
    320
    Meridian Idaho
  20. Ianmeister
    316
    320
    Meridian Idaho
    Thanks for the pointers. If you look up to earlier posts you’ll see the list of things I decided to replace. Add to that list all fluids, radiator hoses and the thermostat. The PO replaced the water pump 1000 miles ago with the correct unit.
