Hey kids! New acquisition.
Discussion in 'Gen 3 Prius Main Forum' started by Ianmeister, Sep 16, 2020.
  1. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Those rags are the wrong color! They won't work!!!!! :mad::confused::eek::barefoot::cry::LOL::ROFLMAO::whistle::whistle:
  2. Ianmeister
    Ianmeister Active Member
    316
    320
    Meridian Idaho
    mikey_t, Mendel Leisk and Raytheeagle like this.
  3. Ianmeister
    316
    320
    Meridian Idaho
    This is the only way I’ll get this done while we’re still young. D6DF7F46-9D4E-42C3-BBE3-F3E278EF0105.jpeg
    mikey_t, San_Carlos_Jeff, SFO and 3 others like this.
  4. ASRDogman
    8,070
    4,092
    Very organized. It makes the job easier...
  5. Gliderguy
    Gliderguy Junior Member
    46
    Prescott Valley, AZ
    Heh, I used the exact same Harbor Freight floor jack to do my work. The little jack I had bought didn't lift high enough to get the wheels off the ground from the recommended lift points, but the red Pittsburgh jack was perfect. I used a lot of snack bags too, but was not quite as diligent as you were.
  6. Ianmeister
    316
    320
    Meridian Idaho
    Ok timing marks 1, 2 and 3. Look good to me! 363A26D2-9098-4FAA-8515-7F6342A50BC2.jpeg D2A38409-5BF4-436F-BED6-EBDE8484734D.jpeg 4A7E44F4-CEDE-4774-9D62-662786D41FDD.jpeg
    SFO, ASRDogman and Mendel Leisk like this.
  7. ASRDogman
    8,070
    4,092
    Looks good! Did you rotate 720 degrees and check that all the timing marks lined up?
    I don't think the colored links will, but the timing marks should.
  8. Ianmeister
    316
    320
    Meridian Idaho
    Ok. Timing cover, check! Crank pulley to 87 ftlbs, check! Motor mount, check! Bed time! Check!
  9. Ianmeister
    316
    320
    Meridian Idaho
    Arg! Word to the wise. Secure the fuel injector rail BEFORE you attach the EGR assembly! 633C9C3A-1602-4A19-892A-98658F0CA28B.jpeg
    SFO, Mendel Leisk and The Critic like this.
  10. Mendel Leisk
    42,387
    Just editorial: pic is upside down.
  11. Ianmeister
    316
    320
    Meridian Idaho
    stand on your head then
  12. Ianmeister
    316
    320
    Meridian Idaho
    Good lord. That black ribbon in the picture is the transmission fluid!! 8EF1F58B-87C2-4C69-BD4D-716CA3313D52.jpeg
    mikey_t, Mendel Leisk and SFO like this.
  13. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    Lifetime fluid....that means whenever the transmission fails due to nasty old fluid,,,,that was the lifetime of the transmission!
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    On the keyboard, hold the keys CTRL, ALT & then down arrow for the quick fix.
  15. Ianmeister
    316
    320
    Meridian Idaho
    Hey Grit. Someone told me you have a thread discussing your amazing mileage achievements. I tried the search feature with no luck. Can you refer me to the thread?
    SFO likes this.
  16. Mendel Leisk
    42,387
    Now I'm more used to it upside down. Anyway:
  17. ASRDogman
    8,070
    4,092
    Well, now it crooked.... :rolleyes::whistle:
  18. Ianmeister
    316
    320
    Meridian Idaho
    im showing how I had to unbolt the EGR and scoot it over to slide the injector rail in.
    ASRDogman, SFO and Mendel Leisk like this.
  19. Ianmeister
    316
    320
    Meridian Idaho
    Looks like I’m running out of things to forget to reinstall! 4C51F0FE-85F6-4283-BDB4-964558BB7EBD.jpeg
  20. Mendel Leisk
    42,387
    Intake manifold? :whistle:
