Hey kids! New acquisition.
Discussion in 'Gen 3 Prius Main Forum' started by Ianmeister, Sep 16, 2020.
  1. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    im putting in an oil catch can first. Should be here tomorrow.
    mikey_t, Mendel Leisk and SFO like this.
  2. Ianmeister
    316
    319
    Meridian Idaho
    Wow. What a journey this has been. All that’s left is WS transmission fluid (waiting shipment) oil catch can and I can put the manifold back in. Other than that I think I have every hose and sensor hooked back up. Now everyone light some incense and have a chant to the timing chain gods with me! 12692F3E-EA7D-49FD-9475-E5774611E79D.jpeg
  3. ASRDogman
    ASRDogman Senior Member
    8,049
    4,082
    I might have missed it, but did you rotate the crank 70 degrees and check to make sure
    all the marks lined up?
  4. Mendel Leisk
    42,284
    720 degrees?
    Basically two revolutions? Of the crankshaft?
    The tensioner gizmo is doing its thing?
    Ianmeister likes this.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Might want to crank the engine using Techstream to prime the oiling system before doing your first start.
    Raytheeagle and SFO like this.
  6. ASRDogman
    8,049
    4,082
    360 = 1 revolution
    360 X 2 = 720
    4 stroke engine, needs 2 rotations to get back to TDC for #1, intake stroke.
  7. Ianmeister
    316
    319
    Meridian Idaho
    Yes
    ASRDogman likes this.
  8. Ianmeister
    316
    319
    Meridian Idaho
    I don't have techstream. I'll look into it.
  9. ASRDogman
    8,049
    4,082
    I just caught my error! Typed "70" instead of "720".
    A mind is a terrible thing to waste...
  10. Ianmeister
    316
    319
    Meridian Idaho
    Aaaarg! I got it all back together and the screen says “check hybrid system” and the code reads P3191. What does it mean?? When it starts it runs smooth for a minute. I did clean out the. Throttle body with carb cleaner.
    #110 Ianmeister, Oct 11, 2020
  11. Mendel Leisk
    42,284
  12. ttou68
    ttou68 Active Member
    351
    211
  13. Ianmeister
    316
    319
    Meridian Idaho
    Oh sorry. I was frazzled. I cleaned the throttle body during reassembly. Now it gives me the result I posted above. I keep reading that improper cleaning may be bad for it? I’m not sure. It seems that MFS seems to be the most likely culprit. I HATE when a car has a particular code that could mean any of 10 different problems that range from $20 and 5 minutes all the way to another tear down!! Grrrrr!
  14. ASRDogman
    8,049
    4,082
    Did you use the carb cleaner on the MAP? Or MAF??? That's a big no no. :)
    They have cleaner for that.
    #114 ASRDogman, Oct 11, 2020
  15. Mendel Leisk
    42,284
    What's MAS? Did you mean MAP (Manifold Absolute Pressure)? That sensor's below throttle body, around 3 o'clock. It looks relatively bullet proof, but who knows; wouldn't hurt to use MAF (Mass Air Flow) sensor cleaning.
  16. ASRDogman
    8,049
    4,082
    Yea, the sensors on the intake manifold thingamabob...
  17. Ianmeister
    316
    319
    Meridian Idaho
    no. I think I figured it out though. See below.
  18. Ianmeister
    316
    319
    Meridian Idaho
    Well kids. I think I found it.... will a gen2 blade work??? 44ACBF28-A818-4D1F-A0B3-DAFFED98E81F.jpeg
  19. ASRDogman
    8,049
    4,082
    Looks like you have one a little low, and one a little high.
    Seems like that is kinda normal. :)
    Does the car run? You said it funs fine for a minute. Do you shut it down???
    Are you able to clear the codes with techsctream? Seems you need to drive it to charge
    up the battery.
  20. Ianmeister
    316
    319
    Meridian Idaho
    If i clear the engine code with torquepro It starts and run smooth for about 15 seconds. Then shuts down and says check hybrid system
