Hey kids! New acquisition.
Discussion in 'Gen 3 Prius Main Forum' started by Ianmeister, Sep 16, 2020.
  1. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    So far so good. The first one I tried was a known bad cell. The discharge recharge cycle took a few minutes and the load test failed it instantly. The others are passing as better than the example video I saw.
    Raytheeagle, SFO and Mendel Leisk like this.
  2. Ianmeister
    316
    319
    Meridian Idaho
    C72E8FC3-6B19-4E76-8113-10D6028B719D.jpeg So there’s are no marks, no broken or damaged clips. This is virgin territory, an original battery!
  3. Ianmeister
    316
    319
    Meridian Idaho
    Hey wait a second!! why does this car have no battery vent rubber tube thingies???
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    A lawyer decided they were no longer needed.
  5. Ianmeister
    316
    319
    Meridian Idaho
    Really?
  6. Ianmeister
    316
    319
    Meridian Idaho
    So while I’m waiting I may as well improve the connection. All the battery nuts and bars were green. So a vinegar soak them polish with fine sand paper. Before and after C09EDC9D-5B91-4F9A-9323-70CD67608850.jpeg
    Mendel Leisk, SFO and Raytheeagle like this.
  7. Ianmeister
    316
    319
    Meridian Idaho
    Well folks. There she is! All back together. Wish me luck! EA69E118-43CD-4785-A28D-C8C9A634535B.jpeg
  8. ASRDogman
    ASRDogman Senior Member
    8,056
    4,084
    Is this the original pack? With the changed cells?
    Wonder why the vent tubs are missing???
  9. Ianmeister
    316
    319
    Meridian Idaho
    I don't know, but the main tube that leads out of the car isn't there, and the hole its supposed to pass through has a factory blank plug in it. I'm pretty sure that this is the original pack and that the rubber vent tubes were never there.
    San_Carlos_Jeff and Mendel Leisk like this.
  10. BestUsernameInTheWorld
    BestUsernameInTheWorld Junior Member
    US
    You better do the "lick test" before you install it. Gotta make sure it's holding a charge.
    The best signature in the world.
  11. Ianmeister
    316
    319
    Meridian Idaho
    Well folks, i got it all back together. Still no love. I managed to get a techstream sorta working, but it keeps crashing. I’ve made it to here so far 258FE97C-4024-4526-8DBC-D79A88A005B6.jpeg
  12. ASRDogman
    8,056
    4,084
    Wow, that's messed up(side down)! :)
  13. Ianmeister
    316
    319
    Meridian Idaho
    sorry, didnt see it on my phone. I was able to see ODB codes, but anything further the program freezes and windows shuts it down. this is a 64 bit computer that I have supposedly tweaked to work techstream. maybe I need a 32bit
  14. ASRDogman
    8,056
    4,084
    I "think" they have a 64 bit version. That's what I have, or so I'm told. I quit losedoz about 19 years ago.
    I couldn't get it to work, it's such a pain! So I contacted the people I bought it from, and they ended up
    connecting to my computer and spending about 2 hours farting around with losedoz before getting it to work.
    If you contact the place you got it from, maybe they can log on to your machine and get it working for you.
    #154 ASRDogman, Oct 27, 2020
    Ianmeister likes this.
  15. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Which OBD codes did you retrieve?
  16. Ianmeister
    316
    319
    Meridian Idaho
    P3191
    P3190
    P0102 this one pisses me off, i replaced the MAF, it went away, then came back!
    P0113 same here
    P0A0F
  17. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Have you investigated the fuel pump:whistle:?
    Some of the codes are leading there;).
    Good luck and keep us posted(y).
  18. Ianmeister
    316
    319
    Meridian Idaho
    I doubt its the pump. If I sit there and keep clearing the codes it will keep running. There is a fuel pressure test on techstream I want to try but Windows keeps closing the program.
  19. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  20. Ianmeister
    316
    319
    Meridian Idaho
