Hi all. New here.
Discussion in 'Gen 2 Prius Technical Discussion' started by Bob Holliston, Jun 26, 2012.
  1. Bob Holliston
    Bob Holliston Junior Member
    32
    Bought a totaled 2005 Prius and fixed it. Runs and drives fine, but one mystery remains: Behind the left front fender is a 2 pin connector that goes to a small plastic broken part with a resister on the black wire. the other wire is red.The wires that go to the connector are: one is red , the other is white with a black stripe. I showed the broken part to the Prius tech at the Toyota dealership and he had no clue. Can anyone solve this mystery? Thanks, Bob
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    That resistor is probably a thermistor. Using an ohmeter, put it into some ice water, and see if the resistance changes. It could be coolant tank temp sensor, the ambient air sensor, or the A/C evaporator sensor. Where was the damage?
  3. Bob Holliston
    32
    Thanks for the reply. That sounds right. The broken part is the female part that the plug plugs into, about a cubic inch and looks like it's a standalone. Going to the dealership this AM to pick up a part and will try to put a little pressure on'm. Thanks again. Bob
