Hi all, new Prius v owner
Discussion in 'Prius v Main Forum' started by farmecologist, Jan 31, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    You’ve pulled the orange plug out:whistle:?
    If so, both sides of the battery are isolated, but no reason to let your guard down;).
    Test before touch and use non-conductive tools. You can still get small shocks from the individual modules, but not the big one that ruins your day.
    The orange plug is the key(y).
    farmecologist likes this.
  2. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Yep the big orange plug was removed. (y)
    • Edit: See bonehead move discussion in post #144 below. Needless to say..make sure you slide the loop on the orange plug to the right after reinstalling! o_O
    Now that I know how to do this and not shock myself to death...it should be pretty easy to install a Prolong harness. I wonder if I can get just the harness for now....because I'll need another harness for the 2010 liftback anyways when I pull the trigger on the Prolong system. So do you feel the Prolong system is worth it? Looks like they are going commercial so it must have some benefit I would think. :D
    #142 farmecologist, Jul 24, 2018
    Raytheeagle likes this.
  3. PriusV17
    PriusV17 Active Member
    440
    207
    CA
    2017 Prius v wagon
    That's crazy amount of dust!
    Did you get a voltage reading for all the modules? Curious to see how far apart they are from each other.
    I'm planning to install a plug-in charger to keep my existing pack topped at 80%. Sometimes I'm at home and it's 20% SoC. Then after that I hope to convert to LiFePO4 but won't be for a few years from now. I need to make sure the right modules exist. I'd like to replace the existing NiMH to LiFePO4. I have also began asking LiFePO4 manufactures to look into creating Prius module upgrades. This would make it a plugin with a decent electric range.
    This guy modified his Prius to run on LiFePO4.
    Just a warning: Modifying a Prius outside of manufacture specs can be dangerous!
  4. farmecologist
    1,960
    1,801
    Southern MN
    Now that is some interesting stuff! Having extra battery capacity like that certainly would be helpful....but I'd have to see about the cost. I can't imagine his project was cheap.
    I'm pretty well versed on the mechanical side of things now ( read this thread for the full saga if interested ):whistle:. However, I'm new to the electronics side. In fact, I did a bonehead newbie thing that gave me a scare after inspecting the battery compartment for the post above. My son called me saying the car would 'turn on' but wouldn't go into gear...it stayed in neutral. I thought I had done F'ed something up! Turns out that I had not slid the 'loop' on the orange plug to the right after reinstalling it. :oops::oops::oops:. Works like a charm now. (y)
    I'll have to get a voltage load tester and learn how to test the modules without getting zapped. I think I have a mild phobia of getting shocked after an 'incident' that happened a few years ago. :whistle:
    As for the dust...yep, the previous owner ran the vehicle in an extremely dirty environment. The dealer cleaned it up nice enough that some idiot like me would buy it...I should have looked closer at the time ( I did get a great deal though ). I've gotten it pretty much totally cleaned up by this point but there is *still* some dirt coming out of nooks and crannies after a car wash.
    I hope the dusty battery modules don't affect performance much. If I ever get the courage it might be good to disassemble and clean the battery at some point.
    #144 farmecologist, Jul 24, 2018
  5. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    If you're taking it for a long road trip, it's too bad you can't clean up the dust. It may affect not only performance but the heat may build up due to poor air circulation.
    The fastest way to check the module voltage is using the Dr. Prius app (since it's free) but you will need ODB2 with Bluetooth. It would give you a good idea if any of your modules are really out of sync. It's seems the last owner was a bit reckless on the care and maintenance side. But you gain a lot as a result.
    Have fun on your road trip (y).
  6. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    I’m a believer and after Sunday, I’ll have another co-owner:).
    So three people sharing the same equipment all with their own harness equals lower cost of ownership ;).
    The equipment works and since I have a 1 year old Lexus RX450h to compare battery performance against, I’m seeing similarities :).
    Not bad for a 9 year old battery and now even lower cost of ownership (y).
    SFO and farmecologist like this.
  7. farmecologist
    1,960
    1,801
    Southern MN
    Dr. Prius looks nice. However, I don't have a bluetooth OBD2 Adapter ( only WiFi ). Looks like Dr. Prius wants a fee for WiFi use?
    I'd like to purchase a Bluetooth adapter anyway so now appears to be the time. (y)
    Edit #2 : Went with this one...
    It seems to be the unit that the EngineLink web page recommends...and has an auto-off feature ( the unit I have now seems to draw power all the time...not good ). We'll see if it works with the Dr. Prius app. I don't see why it wouldn't.
    #147 farmecologist, Jul 25, 2018
  8. farmecologist
    1,960
    1,801
    Southern MN
    Ok good. I think I will get it at some point. Geez..they sure stick it to ya on the extra harness pricing though!
  9. farmecologist
    1,960
    1,801
    Southern MN
    oops - posted by mistake.
  10. farmecologist
    1,960
    1,801
    Southern MN
    I got Engine Link up and running on my old OBD2 reader. Coolant temps, etc...all look good.
    Here are the voltages :
    This one is while driving :
    This one is at a stop light.
    Even though they are dusty.....it looks like the cell blocks are in good shape? Anything else to check?
  11. Air_Boss
    Air_Boss Senior Member
    4,261
    1,197
    New Yawk
    It's a layup.
    Raytheeagle and farmecologist like this.
  12. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Not a softball:whistle:?
    I like the easy ones:p.
    farmecologist and Air_Boss like this.
  13. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    Wow. Interesting. I would see how much voltage drops if you leave it unused for 1 or 2 full days. You may want to compare the results with your liftback.
  14. farmecologist
    1,960
    1,801
    Southern MN
    Interesting in what way? The voltages or the dust? The voltages have been consistent. (y)
    I was looking for a cell block that was lower than the others From what I understand that is a good indicator of something starting to go awry. Correct?
    BTW - These ‘low energy’ Bluetooth OBD2 readers are great. My LELink II arrived a few days ago and it works flawlessly.
    PriusV17 and Raytheeagle like this.
  15. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Usually the module blocks will be within 0.1-0.3 volts if one another;).
    A code is illuminated when the block is 1.2 volts or greater less than the others. This indicates one of the 6 cells in a module are bad:(.
    But quick charge and discharge cycles indicate imbalance;).
    Hope that helps(y).
    PriusV17 and farmecologist like this.
  16. farmecologist
    1,960
    1,801
    Southern MN
  17. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    Impressive. How did the car perform? MPG? Any problems came up? Any big drop in oil?
  18. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    I notice our Prius v (and Gen 3's in general?) are missing vent tubes?
  19. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    I'm thinking if the air is not being forced out through the tubes then having them may serve no purpose.
  20. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    Looks like same is true for Gen 4 NiMH packs.
