Hi guys, newbie, with power steering question
Discussion in 'Gen 2 Prius Technical Discussion' started by Oldgolpher, Jun 20, 2026.
  1. Oldgolpher
    Oldgolpher New Member
    NH
    Not really prius owner but have question about '06 sensor wiring. I have an old chevy truck and lots of arthritis, so decided to try to meld prius power steering into the camaro column in the truck. I cut and machined the shafts on the motor to fit and was drilling holes to pin the double D female to prius shafts when the whole thing went off the drill press table and fell to the floor. The problem is the connector that goes to the sensor circuit board caught in the table slots and the wires pulled out of the sensor board. I found no part of any connector (receptical)or pins and only wires with bare strands stripped to about 1/8 inch that I think went in a white plastic receptical on the board. The problem is I can't find drawing to show where the Black, yellow, red and white wires go at the board end of the cable with green sleeve over it. The 8 pin connector at the end that goes into the control box (P10) has blk - 8, yel - 7, red - 6 and wht - 5, and that end appears to be fine.
    I tried local Toyota dealer but they want to sell a whole new assembly.
    Can any of you tell me what order by color the wires at the sensor end of that green cable go onto the sensor circuit board in the little rectangular box with the blue cover? Or a drawing? Or where to get same?
    thank you,
    Oldgolpher
  2. ChapmanF
    19,050
