Hi I have a 2011 Prius 4 ...what do Codes : P0301 & P219A Mean ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jollymon, Mar 1, 2020.
  1. Jollymon
    Jollymon Junior Member
    Saint Simons Island , Georgia
    Check engine light came on , had Codes Read @ Advance Auto ... Also car Knocks , Shakes until I'm going over 60 +
    What does this mean and what do I need to do ?
    Also what OBD Reader is recommended that I can Purchase ?
    Thanks !
    #1 Jollymon, Mar 1, 2020
  2. Mendel Leisk
    40,586
    Could be head gasket failure, at cylinder #1 (passenger side end of engine). How many miles on it? Have you ever cleaned the intake manifold and Exhaust Gas Recirculation components?
    m.wynn and SFO like this.
  3. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I don’t know Is the gas good?
  4. ChapmanF
    17,349
    P0301 means a misfire in cylinder 1, for any of the usual reasons (they don't all have to be THE BLACK DEATH).
    Anybody find P219A in a 2011 manual? It's not in my 2010 book. Was that code read with Techstream, or some other tool?
  5. Elektroingenieur
    2,515
    3,277
    Three Touring
    The Repair Manual (more info) for 2011 says diagnostic trouble code (DTC) P219A is Bank 1 Air-Fuel Ratio Imbalance. The detection condition is an “air fuel ratio imbalance between the cylinders” that exceeds any of several thresholds.
  6. ChapmanF
    17,349
    Thanks. I would then suspect that the P219A is simply secondary to the misfiring in cylinder 1, causing an unexpected amount of unburned fuel to be present in the exhaust.
    Elektroingenieur likes this.
  7. pjksr02
    pjksr02 Active Member
    532
    226
    Connecticut
    How many miles are on the car?
  8. Nphra
    Nphra Junior Member
    38
    Hello did anyone find a resolution for this issue ?
    I have P219A and P0102 similar issue to this.
