hi :) ....just started looking at the prius
Discussion in 'Newbie Forum' started by Ncage1974, Dec 16, 2011.
  1. Ncage1974
    Ncage1974 Junior Member
    Illinois
    After much frustration with toyota over the 2012 Camry hybrid (availability). Good lucking getting a le model. If you want a fully decked out TCH (XLE) for $35k msrp then you can find one. I can't even build on on their site in my area or Chicago or St.louis. If you live in Clevland OH then your in luck.
    Anyways i digress.
    I'm looking at 2011 or 2012 Prius (either a II or a III haven't made up my mind yet and have lots of questions).
    1. I'm curious about some of the details of the synergy system. I've heard it can run on all electric for up to 40mph. If your below that say at 55-65 mph are you using partial electric/gas or is it all gas at those speeds. Didn't know if both could contribute to driving the wheels at the same time.
    2. How does the prius do on snow/ice?
    3. How are the back seats for a baby seat?
    4. How about at speeds between 70-75? Is the prius stable enough?
    5. How roomy is the prius compared to the TCH. The TCH doesn't seem to get that much worse mileage anymore (~10mpg)
    6. Is there much difference between the 2011 & 2012 prius where i should make sure i get a 12?
    My driving habits. I would say 90-95% of my driving is back and forth to work where most of the roads are highway speeds (55mph) but that have stoplights every few miles and i the timing of the stop lights is horrible and seem to get the red light at every one. My drive is about a 20-25 min drive.
    No matter what direction i go its going to be a hard move for me though :p. I'm coming from a loaded Lexus IS350.
    thanks everyone...
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard!
    1. Up to 46 mph is possible (warm, down hill, full battery). Yes, it is the combination that provides the great FE.
    2. The prius does just as good as any other front wheel drive (with proper tires) on the ice and snow. I would even say it does better because of the TC and ECO mode combination.
    3. Don't know. But we used a booster seat that fit just fine.
    4. Spend most of my time @ 60-65. Got it up to 78 one time and it was smooth as butter.
    5. Don't know. But the roominess is amazing.
    6. Very little between 10 - 11. I really like the refresh on the 12 though (looks).
    That commute should net you well into the 50s if not 60s mpg.
    Good luck.
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Loaded Lexus IS350 :eek: Prius can't quite stand up to that, but a loaded out Prius v with AT package would get you close in terms of comfort/style.
    6) The 2012 regular Prius Four and Five will gain an 8 way power Softex driver's seat. Two will get touchscreen and USB port. Three gets nav and backup camera, loses the JBL audio which is only in the Four / Five with HDD nav package (like AT pack on Prius v). The exterior updates looks nice on '12.
    5) Regular Prius a couple 3" narrower than TCH. Don't consider my '11 a car for 5 adults in terms of size or its 825 lb total load capacity. Prius v matches the TCH for load and room
    4) Haven't cruised at 70 MPH, but regular Prius should do pretty well. Little affected by crosswinds. Prius v ride quality even better. Sure the v will tear up 75 MPH all day long.
    3) Sure you can get baby seat in regular Prius. Little tougher to put in with sloped roofline, but doable. Prius v designed more for family use.
    2) Live in SF Bay Area. No experience w/ snow/ice.
    1) HSD can absolutely employ electric and / or gas simultaneously. Has planetary gearset with ring gear, sun gear and planetary carrier (aka 'power split'). Wheels, electric motor and gas engine connected respectively.
    Take off slowly, runs on electric, can creep through any parking lot, drive through, pull into garage on electric.
    Take off with flow of traffic, I can get to about 10 MPH electric, but higher power demands invoke the gas engine. No worries, it's extremely smooth! It can propel electric to over 40 MPH, but only at very light throttle.
    Lift off gas pedal, engine lays out, no gas burned, coasting and braking recharges system and has regenerative braking. Gas engine off at every stop light unless heater is blasting, it may turn on.
    Heavy acceleration will use gas engine and electric drive. Best to look at the system icon on info display to see which way energy is flowing from/to gas/electric.
    ......... Or you could get the Plug-in Prius in a few months and do all electric (under 62 (?) MPH) for up to 15 miles.
  4. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    You can answer most of your questions yourself by renting a Prius for a weekend from hertz or any rental agency, your own experience with the car is better than any of our opinions. I will offer one opinion however. Since you are coming from a Lexus, you should probably look at the Prius 4. Good Luck:)
  5. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    Welcome aboard, ncage! :welcome:
    It sounds as though you might want to enter the world of hybrids slowly, not rushing into it. So in my opinion, I think it would be a good idea to trade me even: your fully loaded IS350 for my fully loaded ('04) Prius.
    It's a win-win!
  6. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I think that in terms of the tangible items the Prius will be just fine for you. It is a remarkably roomy car that drives well. It is as good in the snow as any front wheel drive car as long as you have good tires on it, and if you feel like you need more grip you can spent $500 or so and get snow tires on steel rims (keep in mind that you will split the wear between the 2 sets of tires so it is not as expensive as it first sounds). The car drives great at highway speeds. Really the only driving issue is that the car is not terribly powerful and that is more of an issue around town - it is not a big deal though once you get used to it.
    The bigger issue though is one that you did not mention. Coming from a Lexus you are giving up a huge amount of creature comforts. I went from a fairly loaded VW Passat to my Prius and it was and still is something that I notice. At the time I was living in Philly but working during the week in Providence RI so I was driving about 1,100 a week so I really did not care. My big beefs are the cruddy seats and the road noise. I'd recommend that you drive a Prius a fair bit and make sure you can live with it.
    One car that you may want to look at is the Lexus HS - it was a slow seller and they recently announced that it is being discontinued. There should be some still on the lots and you may be able to swing a good deal on one - it would get you a fair bit of the comfort you currently have and still get a pretty good boost in mileage (I believe the HS gets in the low 40's).
  7. hill
    9,041
    Your looking journey will be most enjoyable, it if follows many of ours.
    Welcome!
  8. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Like others said, rent one for several days, not just one. Commonly mentioned that seats are cruddy, but that's highly subjective. I find them quite good for the class of car. The 2012's power seat should take care of most complaints.
    oh, SteveMc above has the 2009 Prius ... ah yes, 2nd gen dr. seat, oooh, didn't work for me, eeeeek. I p$$d away $14,000 total to get out of that situation. So, yes, rent for multi-days before buying, not just one day like I did back then.
  9. Ncage1974
    Illinois
    Hi guys. Thanks for all the responses and sorry for taking so long to get back with you all. Its been a busy weekend.
    Ya i know i won't get anywhere near the luxury of my lexus and i'm ok with that. The lexus was a single car for me and i'm now married :p.
    I went to my local toyota dealership and i found out they can finally get me a Toyota Camry Hybrid LE if i want (he said as long as i'm not that picky on color). I've never had to get a car that they had to ship to the dealership but i imagine this means that is going to be harder to haggle with the dealership on price. I know right now i should get quite a bit more than i owe on my lexus and i won't let them rip me off thats for sure.
    I also talked to him about the plug-in prius because i was curious. He said we definitely won't see one in our area for quite awhile. He said and even out of the rare case we do your going to have to pay WELL above MSRP to get it (pretty much what i expected). He said even if i was to try to get one in Chicago it would be hard.
    None of the dealerships around here have 2012 prius currently (unless you want a V and i don't) so maybe i'll just settle for a 2011.
    Its a hard choice. If i get a Camry i won't even be able to test drive it. It also concerns me this is a new model year and probably don't have all the bugs worked out yet. Especially considering its a hybrid variety and a lot more complex than your run of the mill car. I had that happen to me when i got my 2008 Accord. Had all kinds of small issues with it. But on the +side this thing gets only 10mpg worse than the prius which is outstanding considering how much bigger it is.
    Your guys idea to rent a prius was an excellent idea. I went by enterprise on Friday and asked him if they rent prius and he pretty much said no they only have a couple in the fleet. So i guess i will call some others on Friday to see if i can get one to rent.
    Its a really tough choice thats for sure.
  10. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    4. It was stable at 107 mph. Enough said.
  11. Ncage1974
    Illinois
    Well looks like i'm out of luck in renting one. They are just not plentiful in my area and since i don't live in a huge city probably less so. Enterprise pretty much told me they only have 3 in their entire fleet and they are real hard to come by and i did a search on hertz and they aren't available in my area.
