Hi,need help and suggestions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rk Rafi, Apr 27, 2026.
  1. Rk Rafi
    Rk Rafi New Member
    London
    Today my toyota Prius t spirit 2010 comes with that dashboard warning light and car didnt start.After few minutes all warning light gone and car restart. Why that happend and how to fix it. Iam worried. I got this car only few days ago.
    52,857
    maybe a low 12 volt battery
    Rk Rafi and Brian1954 like this.
  3. Rk Rafi
    Rk Rafi New Member
    London
    Does it need to replace?
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,350
    980
    Monument, Colorado USA
    I agree with Bisco....if we have any electrical issue in these hybrids, the first, and easiest, thing to check is the health of the 12-volt battery.
    If you don't have a good battery tester, auto parts stores have them you can borrow (or they'll test it for you.) You don't just want to check the current charge in there, it has a % of health and anything below 70% should be cause to replace it ASAP.
    Rk Rafi likes this.
  5. Rk Rafi
    Rk Rafi New Member
    London
    I think 12v battery problem
  6. Rk Rafi
    Rk Rafi New Member
    London
    When i take off footbrake its go away automatically
  7. bisco
    52,857
    you could try charging it and see how long it lasts. how old is it?
  8. Rk Rafi
    Rk Rafi New Member
    London
    I dont know about battery age.Recently i bought this car.
  9. bisco
    52,857
    you'll have to decide between a battery charger and tester, or a new battery. and still, the battery might not be the problem
    Rk Rafi likes this.
  10. Rk Rafi
    Rk Rafi New Member
    London
    Thanks for your suggetion
  11. ChapmanF
    19,025
    Are you positive you had the brake pedal firmly depressed the first time? If you don't, the car goes to ACC and then IG ON instead of READY, and in IG ON, most dash warning lights will be on, which is normal then.
    Rk Rafi likes this.
  12. Rk Rafi
    Rk Rafi New Member
    London
    This is dr prius report
