Hi there.. I have 2010 toyota prius gen2.
Discussion in 'Gen 2 Prius Main Forum' started by Shahrukh, Sep 9, 2020.
  1. Shahrukh
    Shahrukh Junior Member
    Pakistan
    I have gen 2 prius 2009. My car ac is ok on cold but after drive for 30 mins, it goes off and remains off for 20-30 minutes then come backs on for 2-3 minutes... If i cool down radiator with water, it comes back in a minute. Radiator and hybrid coolants are changed, fan speed is ok, water running is ok.. Where can be the problem?
    49,516
    check the inverter fluid reservoir for movement
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Search "prius inverter pump failure".
    GOOD LUCK!
  4. Shahrukh
    Pakistan
    I checked. Coolant flow speed is excellent in reservoir... One last check left.. The radiator blockage with dust etc btw ac condenser and radiator.. Both are stick together in prius
  5. Shahrukh
    Pakistan
    Thanks God,, the problem is solved.. There was lot of congestion btw ac condenser and radiator.. I just cleaned and air was able to flow between both condenser and radiator...
  6. Shahrukh
    Pakistan
    I cleaned it all
  7. Shahrukh
    Pakistan
    The tool i made from the wind screen wiper iron wire... With nylon net wrapped on it.. I cleaned between both radiator and condenser with it then rinsed with water pressure... All the work done without removing radiator from the car...
    SFO likes this.
  8. Shahrukh
    Pakistan
    Oooh..... Pretty much cold ac today...
    I am sure this thread Will help many old prius owners
  9. fotomoto
    5,602
    3,779
    So. Texas
    I totally missed the "A/C" part in the OP. :oops:
    Yes, airflow is critical for a/c performance. If the a/c performance improves with road speed, check the "radiator" for issues like you found and the radiator fans for proper working. The fans not working is the more common failure of the two issues.
  10. bisco
    49,516
    wow, that was bad! are those spiders friendly?
  11. ChapmanF
    15,696
    It's Charlotte!!
    Did the radiator say RADIANT ?
