HID bulb replacement (90981-20007)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by WToyotaM, Sep 4, 2018.
  1. WToyotaM
    WToyotaM New Member
    Highland Park, IL
    I've got the bulbs now, but I'm having a DEVIL of a time unscrewing the waterproof cover that surrounds the bulb fixture.
    I'd rather not apply too much elbow grease out of fear of breaking the cover.
    Does anyone have any advice as to how to loosen the waterproof cover?
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Do you have the fixture out of the car?
    Or did you choose to leave it in the car?
    If you have it out, you can see the arrows on it that show which way to turn it for locking/unlocking.
    And when it is out it is much easier to get some leverage on it.
    It only turns a short way, so if you see you have moved it past the unlocking point you can check to see if it pulls open.
    davecook89t likes this.
  3. WToyotaM
    WToyotaM New Member
    Highland Park, IL
    The fixture is in the car. I'd rather not pull the whole assembly out, as I'll have to take multiple components off the front of the car, and given that I've never performed a repair like this by myself, I'd rather not risk breaking or losing any additional parts during the bulb replacement.
    Unless there's a tool that will allow me to easily reach around the cover and unscrew it without breaking off any of the fins or causing other damage, I think I'll probably just take the car to a shop so that they can install it. I've found a great reviewed place that'll replace both headlight bulbs for $130 (i.e. total expenses will still be ~$300 less than what I would pay if I had a dealership do everything.)
  4. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    No tool needed, just grip and human force.
    Removing that part is the least of your worries.
    Trying to open the metal retaining bail/clip while "blind" is a real challenge if you have never done one before and are merely groping around guessing how it works.
    It can be a real frustration and is the kind of thing that you might wish on an enemy.
    Once you've done it a few times it becomes muuuuch easier though. But most people don't do it often enough to build the "muscle memory" that make the job easier.
  5. WToyotaM
    WToyotaM New Member
    Highland Park, IL
    Gripping it and forcing it isn't enough. It will NOT budge, plain and simple. If removing the cover is the least of my worries, then I definitely need help from a mechanic to install the bulbs.
    Thank you for your feedback, though.
  6. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    If you want one more go at it...
    Perhaps you already moved it far enough so it will not move further?
    There are arrows embossed onto the casing that hopefully you can see with a flashlight?
  7. WToyotaM
    WToyotaM New Member
    Highland Park, IL
    I haven't moved it at all. I think that the elements have helped cake the cover into its place extra strong, and it feels very much like the fins will give way long before the cover does.
  8. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    That's what I thought when I tried to reach in behind and twist the cover with my bare hand, and then when that didn't budge it, started tapping on one of the fins with a hammer. Eventually, I gave up and loosened the bumper cover enough to pull the entire fixture out of the car, at which point it was easily removed. I then realized I had been trying to turn it the wrong way!:oops:
  9. WToyotaM
    WToyotaM New Member
    Highland Park, IL
    I thought about doing that, but I've read about cases where people break off the fins by tapping it with a hammer.
  10. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    The fins can become quite brittle so I would not hit them with a hammer.
    If you have the following 5 tools you can remove the headlight assembly
    - phillips screwdriver
    - regular screwdriver
    - 3/8 ratchet with short extension
    - 10mm socket
    - vise grips
    I'd be happy to walk you through it.
    Maybe someday I should do a video.
    SFO, rbdigital and davecook89t like this.
  11. WToyotaM
    WToyotaM New Member
    Highland Park, IL
    I have most of those tools, but for a job that requires this kind of disassembly, I'm going to have a mechanic install the bulbs.
    Btw a video still sounds like a good idea for anyone else having trouble with their headlights.
  12. padroo
    padroo Senior Member
    2,763
    2,253
    If you are going to pay someone to do it have them show you how it's done. Next time it won't be so intimidating.
    I watched some girl do one on YouTube and I was never able to remove those covers on the car and always removed the headlight assembly.
  13. WToyotaM
    WToyotaM New Member
    Highland Park, IL
    Roger that.
  14. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Sorry to say, paying me to do the work is one thing.
    If you want me to explain what I'm doing step by step and train you how to do a job, that is a separate service. I'm happy to do it. But it is much different experience for both the customer and me.
  15. WToyotaM
    WToyotaM New Member
    Highland Park, IL
    It's done. The mechanic installed the bulbs this evening and everything's working great.
    Thank you very much for all the feedback.
    ITBland and davecook89t like this.
  16. padroo
    2,763
    2,253
    Did you learn how to do it?
  17. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    And can you share approximate cost
  18. WToyotaM
    WToyotaM New Member
    Highland Park, IL
    Yes, I saw how to get leverage to twist the cover (mechanic used an extra long socket to push and used a screwdriver to loosen, as well). Cost to install both headlights was a combined total of $120, very fair compared to what the dealership wanted for parts and labor.
  19. Prius in Seattle
    Prius in Seattle New Member
    Seattle
    I know this thread is old but this video (below) is the most thorough video on replacing the bulbs on a Gen ll Prius....very detailed.
    All of the others do not show enough detail. It is actually fairly easy to do.
    WilDavis likes this.
  20. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Way easier, faster, and much more accessible by droping the bumper.
