HID Bulb Replacements
Discussion in 'Gen 2 Prius Technical Discussion' started by geopupps, Aug 19, 2018.
  1. geopupps
    geopupps Junior Member
    23
    Phoenix
    Our one headlight seems to be going out after about two minutes on our 2009 Prius. It's mainly the passenger side but if you switch the lights off and back on and they will turn back on. (but only for a few minutes) My wife read since we have the High Intensity Bulbs we can't convert to LED's is this true? and which bulbs would you recommend we should purchase regardless of kind? (We just need headlights that work) Thanks for your time. Have a blessed day/night.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,362
    6,033
    Columbia, SC
    Philips 42406 from HomeDepot.com
    Guaranteed to be genuine and a pretty reasonable price compared to dealers. Also it's one used as OEM for the Gen 2 model.
    It will cure your problem. With HIDs you should replace both at the same time.
    Philips Standard HID 42406/D4R Headlight Bulb (1-Pack)-42406C1 - The Home Depot
    Uh-oh.... just noticed it says "out of stock" sry about that
    Maybe here..and a 20% off offer pops up when I open the website...
    D4R - PHILIPS OEM 4300K 42406 HID Bulb – HID CONCEPT
    #2 TMR-JWAP, Aug 19, 2018
    JC91006 likes this.
  3. geopupps
    23
    Phoenix
    Thanks. Is this the same bulb?
  4. geopupps
    23
    Phoenix
  5. TMR-JWAP
    6,362
    6,033
    Columbia, SC
    Maybe, maybe not. There seems to be an awful lot of counterfeiting going on. Used to be the counterfeits would be so amazingly cheap that it would be obvious they were fakes. Then they got smart and started charging more to make it less obvious. I tend to avoid taking chances on it. There's a pretty good thread in the forum about HID bulbs. I'll try to find it and link it.
    Not all HID Bulbs are created equal | PriusChat
    That thread was started back in 2011 by our own @2k1Toaster
    #5 TMR-JWAP, Aug 20, 2018
  6. geopupps
    23
    Phoenix
    Thanks I'll check it out.
