HID cutoff not as good as I thought?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by F8L, Apr 24, 2012.
  1. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Actually looking for tips on the harness relays.
    Good tip on the zip ties for the ballasts as I did use double sided tape. I added some foam on the side next to the fender for cushion to keep the standard size ballasts from banging against the fender. Slim ballasts would have been better.
  2. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Isn't your harness relays mounted to a small mounting piece? You can zip tie through the opening on the plate and find any area to connect to. The place that did my install, used a self-drilling sheet metal screw and mounted it to the top frame(?) behind the passenger light (in the area right where the opening for the air intake is).
  3. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Yes it has a mounting plate. I actually tried the spot you are talking about, but the power wire isn't quite long enough. I guess I could extend it though. The other option is to place it on the drivers side I guess. I was hoping there were some elegant solutions.
  4. wick1ert
    1,311
    183
    Delawhere
    I'd put it on the drivers side. I'll see what the install shop did with all my wires when I open it back up to replace the driver side light that I broke. There's so many wires and I haven't had a chance to trace it all out yet. Let us know what you decide to do.
  5. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Thanks got the wiring done and I have the bumper and headlights out. Trying to figure out a couple more pieces before I get the nerve up to split the headlights. Unfortunately, these don't come with instructions.
    Anyone know:
    1) Where the high beam solenoid wire passes through the housing?
    2) It comes with a bunch of gaskets. Are those used?
  6. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Hi everyone, Haven't been on here for a while. Busy etc. If F8L is still out there, he had a query whether 55w HIDs would damage stock halogen projector on the 2010 Prius.
    Well, the definitive answer is no. At least with the HID units I am using.
    I was unfortunate enough to hit a roo recently. The left hand headlight unit was totally destroyed along with the left hand mudguard (fender) and the front bumper unit. This enabled me to inspect the glass lens and the reflector. No sign of bubbling, overheating, coating on the lens or reflector or discolouring. In fact it looked to have been pretty well pristine before roo dismantling.
    I still think it pays to buy quality bulbs which can be guaranteed to be UV cut but I am happy with the results of my experiment which has gone on for around 80,000 kms.
    Every thing is covered under insurance, including the headlight modification and I am presently driving a 2013 Camry hire car. But boy I miss my Prius!!!:cry:
    F8L likes this.
  7. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    I don't think there is much diffference between the 55w and 35w HID's as far as output is concerned. All you need is a good projector housing. Very satisifed with the OEM cut off pattern. There is a logical reason for bowing on the sides as far as I am concerned. Makes better visibility on the sides and won't trade it with a traditional straight cut off beam pattern. The cut off beam pattern of the OEM projector looks out of the ordinary. But now I understand why.
