HID cutoff not as good as I thought?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by F8L, Apr 24, 2012.
  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Post #24 is talking about the Harley light......unless I mised something :confused:s
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I am concerned more with the left. I edited my post though so re-read it. I see the upward bow on your left-side beam as well. :)
  3. Tideland Prius
    16,683
    I think I see what you're talking about...
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I realize it looks like no big deal in the pictures you provided but check it again at night and let me know what you think. Also watch passing cars as you drive through neighborhoods or city streets. Are you lighting up their interior or their heads as you make turns? lol
  5. wotcher
    wotcher Member
    403
    97
    16
    LA
    thanks a lot F8L! i was about to buy some xenon depots and my prius this week. i guess ill have to wait for the results before buying one or the other.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No problem. I think. :)
    We'll get this figured out within a few days. I will need to have someone drive my car in the opposite direction of a vehicle I'm driving so I can determine if the glare is unsafe or if lowering the beams will fix the problem if one exists.
  7. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Wow, I had typed up stating that I was going for pictures, and then left without posting lol. Anywhere, here's some pictures with the Morimoto's....There's one from about 15 foot and another about 25 foot. Either that, or I'm really bad at judging distance.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Thanks, brother!
    Yours has the bow but it doesn't look as drastic. I'll try and take more pictures tonight but I'm sitting at a 58.9mpg tank right now and that short trip might ruin it. :p
    If they all look like yours then I would say we are likely not blinding other drivers as long as the headlights are aimed correctly. Nice blue cutoff btw.
  9. Tideland Prius
    16,683
    Ok I see the slight bow in his pic (the middle one that's the farthest away from the building).
    As far as I know, I've never gotten flashed and my hot spot is below the top of the trunk of a sedan and just at the lip with two people in the back. I mean you can eyeball it from that pic above and use the Cobalt on the right as a marker, right? I've driven behind police cars and they never pulled me over.
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I agree. His beams do not appear to have much of a bow. I will check mine again in a different location and see what's up. Good to know the older models look fine with HIDs. Well, I'm still waiting for your night time shots... ;)
  11. Tideland Prius
    16,683
    And I'm desperately trying to think where I have a flat wall and a flat ground to go against (also doesn't help that I'm gaining daylight rapidly so I have to do it quite else I end up waiting til midnight before it's pitch dark lol)
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    L
    O
    L
    I've spent many evenings searching for a good wall. Cops have stopped me for looking suspicious. :D
  13. Tideland Prius
    16,683
    You owe me a warm-up cycle :p.
    And yes, they bow out but I've never noticed it until now when I pointed it against a large, flat wall. It's so far out (at least 3 or 4 parking stalls over)
  14. realbug
    realbug New Member
    Seattle
    I just installed a plug n play HID kit tonight and noticed the exactly same problem. Mine came from xenon supply and costed me around $100, which shouldn't be cheap bulbs I assume. I think it's the light housing causing the problem.
  15. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    I agree, I think it is the optics that are the problem. They were designed for halogen bulbs, and the HID bulbs probably throw their light around inside there differently than the halogens do.
    Do the make a light fixture that is specific for the HID application?
  16. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    You're using bottom of the barrel HIDs, right? Could just be due to the different HIDs.
  17. wick1ert
    1,311
    183
    Delawhere
    I was worried if I went somewhere with one of the rent-a-cop security people, that I'd get hassled. Luckily, that building was 1/10th mile up the road from me at a small medical center. The ground wasn't perfectly level, but it was pretty darn close!
    Those are the 5000k bulbs in mine.
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Not for the gen3........its either halogen or LED.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    At this point I'm not convinced that its the HID bulb.
    Yes cheap bulbs mess up the output.
    Yes HIDs have different optics.
    The problem is not the HID bulb or even the optic of the projector. The problem with this specific issue is the cutoff shield. Here is a pic I took this morning leaving for work. The street light was throwing the amber look but you can still see how the left side of the cutoff bows up & I still have the halogen bulbs in. For some reason these projectors were designed with 2 steps in the cutoff. The bowing that we are seeing is a direct result of the 2nd step.
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Sort of. They are DDM bulbs. As usual these bulbs put out more blue-tinted light than I care for but I expected it with these bulbs. When cash is available I will try a better bulb that better represents the 5000K rating. :mad:
    it's ok if the ground isn't super level. As long as you capture the full spread then you can visually compensate for that. Maybe just tilt your head. LOL
    I should have taken a picture on my garage door this morning when I left. Like yours, it makes the bow appear amplified because it is closer to the car. It looks like a big smile. :)
    I'm very interested in seeing what the cutoff shield looks like. This seems like such an odd design but I'm sure it makes sense to the designer.
