HID Fog & HID Headlight
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Fong, Feb 21, 2014.
  1. Fong
    Fong Member
    85
    32
    Arizona
    Hello Priuschat members:
    Currently running xenonsupply HID 43K for headlights, now looking to upgrade to H11 fogs to same brand and same Temp. Will there be any issue with flicking or anything ? Please list Pros & Cons, if knowledge. Click below link for more info on the kit.
    HID Kits | Xenon Kits | HID Headlights
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    moved from technical to accessories and mods
  3. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I'm using a 35W H11 kit on my fog lights without the relay harness... so far I haven't gotten any problems with it
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    The big problem with HID in the oem reflector foglights is the oem lights don't really have any cutoff to prevent glare.
    Since the HIDs are so bright, it's like driving around with low mounted highbeams on. :mad:
    SCH-I535
  5. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    that's why I'll be replacing mine with this projector type fog lights... (y)
    ptn and xliderider like this.
  6. Fong
    Fong Member
    85
    32
    Arizona
    Thank You, for all you guys valuable inputs. I like the projector fog kit, what is the cost and please provide link for more info.
  7. xliderider
    8,140
    3,280
    Honolulu, HI
    Bino has a lot of money. ;)
    I suspect these would be less $$$ than the ones Bino is getting:
    06 07 08 Toyota Aurion Camry Projector Fog Lamp Light | eBay
    07 08 09 10 11 Toyota Corolla Axio Fielder CREE LED Square Projector Fog Lights | eBay
    First link is Halogen, you may be able to mount HID in them. The thing about mounting HIDs in these small projector housings is that there is very little room for heat dissipation, so you might risk burning the reflector bowls/coatings.
    Second link is LED based, so you will be running lower wattage and running cooler than halogen or HID.
  8. CdotK
    CdotK Member
    376
    46
    and bino can read Chinese ;)
  9. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    :D
    google translate helps me a lot ;)
  10. Fong
    Fong Member
    85
    32
    Arizona
    Thank You for all the links!(y)
  11. CdotK
    CdotK Member
    376
    46
    I know.. i was teasing ya! ;)
