HID headlights dim on Prius Touring
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by woodenpaddler, Apr 1, 2023.
  1. woodenpaddler
    woodenpaddler Junior Member
    17
    Maine
    My 2008 Prius Touring has 234,000 miles and the headlights have seemed wicked dim for a while. I searched through the forum but didn't find a definite cause. I have replaced the bulbs on each side at least once with quality D4R bulbs I believe. I have polished the plastic headlamp assemblies. Toyota dealership said the headlamps were fine, but they are not bright like my Saab 9-3 or my Toyota Tacoma. I don't remember the lights being so dim like this when I bought it at 30k miles. The Prius is well maintained and in great shape and I have no problem putting more into it; just trying to make sure I go down the right path. Should I replace bulbs, replace the whole assemblies, or do more testing?
    thanks for any suggestions.
  2. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    I think ballasts tend to wear at some point I mean the car is a 2006 7 whatever you just said so in that respect those parts are a bit old hell the aftermarket companies I buy some of this equipment from even states in their literature that ballast are one of the first things to check for a week lights That's why I moved everything to halogen housings with the manual adjustments and S1 series LED bulbs If I could get even fake projectors in those housings like the Gen 3 has for the low beams that would be great and wouldn't bother on coming drivers since none of that's readily available for the Gen 2 I have to dip the lights down a little bit with the manual adjustment and that seems to do the trick not the best solution but given the year model and all that it's the best you've got I mean look at older Toyotas we used to drive same lighting problems etc etc all the way back to sealed being glass oh well
