1. Barry Hines
    Barry Hines New Member
    Port Orchard, WA
    Are there any permanent fixes to the headlights malfunctioning?
  2. JC91006
    16,933
    8,643
    From what I've read, it's the bulbs that are bad (bad batches). Maybe try some higher quality bulbs from your local auto parts places
  3. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It would be unlikely that there are still any bulbs in action from the 2005/2006 bad batch. There are really no malfunctions with the HID system. Either it works, or the bulb is out, or very rarely the ballast is out. It's very simple.
    JC91006 likes this.
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I have never heard this before.
    Seems like folks sure have a lot of problems with those bargin bulbs they get on Amazon and eBay.
  5. JC91006
    16,933
    8,643
    Bargain/Retail stuff online.....can be fake/counterfeit. Of course that can happen at a retail store too, but just less likely to happen.
  6. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Besides the references to the bulbs, there are other reasons they fail, just like many other "regular bulb" lights. One of ours started acting up a year ago. The failure was caused by the fixture no longer being waterproof. The permanent fix was to replace both the fixture AND the ballast as I assumed that water had reached the old ballast located beneath the light itself and sooner or later it would need replacing due to corrosion. It's been one calendar year since the replacement and all is well, even in heavy rains now.
  7. Shaunius
    Shaunius Junior Member
    91
    24
    City of Angeles
    Hi Barry I do not think so I had a flicker in my right headlight bought brand new bulbs and ballasts just to make sure it stops and the flicker is now coming from the left side even though both bulbs and ballasts are brand new clearly something this defective on aging 2nd gen headlights other than this issue the car is perfect :(
