HID Kit From Xenon Supply Finally Arrived
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Prius_Cub, Apr 10, 2013.
  1. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    Got the 6000k Crystal White in the High/Low Bi-Xenons but alas the wiring harness/relay wasn't included...:cry: Called Xenon Supply's tech support line and they're sending it out via USPS Priority and should arrive within 2-3 days (free of course). Can't wait to get these installed. Had the passenger side headlight housing out already before I started looking for the wiring harness. 0410131807a.jpg
    Daves09prius likes this.
  2. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
  3. Daves09prius
    680
    161
    Gettysburg, PA
    Are these truly plug and play? or do you have to run a wire to the battery (Positive jumper terminal) in the engine compartment to make the high/low beams work?
  4. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    Yeah, for the gen IIs you need the accessory relay harness to supply power to the bulbs from the positive terminal so that both Hi and Low beam functions work, other than that, everything else is plug & play. Will definitely take more pics once I get the harness :)
  5. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    Got the accessory harness today :) Installed both new HID bulbs and verified functionality. I'd say it took me less than 2 hours but I'm still toying with the wires and hiding everything. Now for it to get dark so I can see how well these do compared to stock halogens.
    Accessory Harness Positive terminal connection:
    Wiring harness connectors, ground connection to upper right chassis, Driver side H4 connector is used just to relay the signal for on/off/high beam control the "control module" while the power is supplied from the positive terminal under the fuse box. The passenger side H4 connection is unused as the accessory relay wiring "control module" determines whether or not the bulbs should be on/off or in high beam mode. The directions indicate that the accessory relay is to be wired up on the passenger side but that's because most vehicles have the battery on that side in the engine bay, but no big deal with the case of the Prius, just use the positive jump terminal. ;) 0413131128a.jpg
    The whole process itself wasn't terribly difficult, I believe I had more of a time working on getting the bumper off enough so I could remove the headlamp assemblies.
  6. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    You will find it a much neater job if you thread the feed wire with the eye on the end up from the bottom of the fuse box following the rout of the the wire from the battery.
    There is enough room to simply push the wire with the eye on the end up by the side of this cable that goes up to the jump point, it also has the advantage that you do not need to cut the box to make an entry point.
    John (Britprius)
  7. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    Thanks :) The wire cleanup is a work in progress, I just wanted to make sure everything worked and it does :)
  8. Mistah Ya
    Mistah Ya Junior Member
    58
    Phnom Penh
    Finish yet? Picture please cos I want to upgrade mine as well!:)
  9. Bronze84
    Bronze84 Member
    118
    25
    South Derbyshire
    Any pics yet Prius cub? I want to compare to mine :)
