HID Lights Aiming Upwards?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by camthelamb, Jun 3, 2019.
  1. camthelamb
    camthelamb Junior Member
    united states
    So I just installed a pair of D4R 6000K Xenon HID lights on my 2007 prius and now they're aiming directly upwards. They don't even touch the road. I tried manually adjusting them with the aiming screws to no avail.
    What could be the problem here? Has anyone ever experienced this? Should I take it to a shop?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Maybe they're upside down
  3. VFerdman
    VFerdman Senior Member
    1,200
    1,221
    Western Massachusetts
    Did you install hid bulbs into halogen housings or did you do a proper projector retrofit? If former, go back to halogens, you will be blinding the oncoming traffic and being “that guy”. If latter, then double check your installation. Properly done hid projector upgrade works very well. Housing do need to be re-aimed. But it’s very much within the range of the system.
