HID Retrofit Questions
Discussion in 'Gen 2 Prius Technical Discussion' started by 1enigma1, Aug 16, 2019.
  1. 1enigma1
    1enigma1 Junior Member
    Hi There,
    My old headlamps all went yellow over the years. I ended up replacing them with the HID versions of the headlamp assembly (long story, but is what it is).
    I need to get the HID bulbs and ballasts all up, but have some questions:
    Background Info:
    1. The factory wiring is standard (ground, high-12V, low-12V)
    2. In know that I will need to convert the factory wiring harness into one useful for the HID Ballast (we can assume it's 81107-51050 or equiv)
    3. I am aware of the 81125-33460 harness, but I cannot locate any photos to confirm if the upstream interface on this harness is correct or not
    4. I am fine with creating my own harnesses
    5. This is a 2005 Prius
    Questions:
    1. The 81107-51050 ballast is not marked with, and I cannot find, a valid wiring diagram showing exactly what the unit expects in terms of connections. Anyone have such a diagram, or know the pin-out for the interface pins? How about one of the 81125-33460 harness (which would show the same info)?
    2. How does the ballast handle high and low beam operations (or does it - not much out there in terms of info)? #1's answer may answer this question...
    3. Anything else I should know?
    4. Is 811235-47001 important in the end (it's the end cap, plastic)? I am not sure which bin it ended up in - if it can be ignored, cool, less to deal with.
    Thanks!
  2. 1enigma1
    Any thoughts?
  3. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Most people go the other way because the HID,s are so much trouble. I suggest you get some new regular headlights cheap on EBay and stick with what you have
