HID to LED conversion
Discussion in 'Gen 2 Prius Main Forum' started by Lloyd-ss, Jan 14, 2018.
  1. Lloyd-ss
    Lloyd-ss Member
    89
    89
    Ivy, VA
    Four Touring
    The LEDs have been in place for 6 weeks now. They are passively cooled with a finned heatsink. No fan. Heat does not seem to be a problem. The entire inside of the headlight assembly is one large compartment, with various partitions, and the entire assembly is sealed, but air can move by convection throughout the headlight assy. The HID ballast, and the HID bulb are no longer active, and they were the sources of heat inside the headlight assembly. I have not put a temperature probe on the LED heatsink to see hot hot it runs.
    Basically, I still like the LEDs EXCEPT FOR the FM radio interference.
    I made an attempt at a repair by installing 2 ferrites from old laptop power supplies. I removed the connectors at both ends of the DC-DC converter and soldered in enough wire to get 2 complete wraps of both leads around each ferrite, one on the input, and one on the output. Unfortunately, it made absolutely zero difference in the FM interference. All FM stations are still nothing but static.
    Maybe the ferrites are the wrong kind, I don't know. What I do know is that I am out of my knowledge base right now and am looking for help. Here is a picture of the ferrite installation.
    SFO likes this.
  2. audiodave
    audiodave Active Member
    800
    272
    US
    I think the interference is emitted from the power supply itself.
    SFO likes this.
  3. audiodave
    800
    272
    US
    SFO likes this.
  4. Lloyd-ss
    Lloyd-ss Member
    89
    89
    Ivy, VA
    Four Touring
    I've got some copper foil. Maybe I can wrap it with that and solder on a ground wire that I can ground to the car body?
    SFO likes this.
  5. audiodave
    800
    272
    US
    SFO likes this.
  6. demag
    demag New Member
    Uk
    I'm watching this with interest, I only have standard halogen and was considering fitting Osram Night Breaker's but will see how this develops. Our rules (UK) have just been tightened for the MOT annual test that bulb types must not be altered. In the past I fitted hids to my Citroen XM and the results were outstanding.
  7. audiodave
    800
    272
    US
    More options for halogen to LED conversions the HID that this is.
    demag likes this.
  8. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Good job! Very good write-up!!
    Lloyd-ss likes this.
  9. Lloyd-ss
    Lloyd-ss Member
    89
    89
    Ivy, VA
    Four Touring
    Thanks for the comments, everyone.
    A couple of updates on the conversion of HID to LED headlights.
    (1) There was a concern about the vehicle not passing state inspection because of changing the "type" of headlight in the vehicle. Well, the Prius just past it's annual state inspection at a Toyota dealership. The conversion is totally invisible unless you disassemble the headlights, so maybe I got lucky on that point.
    (2) The lights have been installed for over 3 months now, with no glitches in operation at all.
    (3) The FM radio interference from the DC-DC power supplies is still unresolved. I think Audio Dave is right and it is being emitted directly from the tiny LED power supplies themselves. Springtime is super busy outside for me, so I will have to "force" a few hours to remove and disassemble the headlights (again !!!!!) to try shielding the power supplies and see if it stops the interference. I certainly hope so!
    Lloyd
    audiodave and SFO like this.
  10. audiodave
    800
    272
    US
    I'm sure some better models will be available without this issue. But hopefully you can correct yours!
  11. davefmy
    davefmy Junior Member
    39
    Ridgeland SC
    Great write-up! Any news on the Radio Noise problem?
    Have had a Blastest blow on the Passenger side and thinking of going this route soon!
  12. Lloyd-ss
    Lloyd-ss Member
    89
    89
    Ivy, VA
    Four Touring
    GOOD NEWS UPDATE !
    DURABILITY - Excellent so far.
    The LED head lights have been performing flawlessly for the 7-1/2 months they've been installed. The car doesn't see a lot of miles, but the headlights are on 100% of the time while the car is being driven.
    PERFORMANCE - decent.
    Not super bright, but the brightness is safely adequate.
    HEAT BUILD-UP - Not an issue.
    It's been blazing hot all summer here in Virginia (94F here again today) and no symptoms that I can detect.
    ERROR CODES - Nothing showing up on the dash.
    LEGALITY - ok, I guess. Definitely maybe.
    Went thru state inspection fine at a reputable establishment.
    FM RADIO INTERFERENCE - FIXED ! !
    Been a while since I posted about this. The problem was that the LED conversion put out some sort of radio interference that made listening to FM impossible when the lights were turned on. AM was fine. It also caused interference in any cars that were directly next to it. Looks like the problem was the cheap DC-DC convertor power supply that came with the lights. First I tried ferrite donuts on the input and output of the convertor. No help. Then I wrapped the convertor and donuts with thin copper foil. No help. Frustrated, I stopped messing with it.
    Then davefmy posted today and I figured, what the heck, let's take one last shot at it. I had been meaning to ground the copper foil but had never done it. (Audio Dave, I bet you are laughing.) It was hot outside, but at least i had some shade, and I was hot and sweaty already, so I pulled the headlight out AGAIN, took it into the garage. Un-did the round cover and pulled out the convertor that already had the copper foil wrapped around it, and soldered a 6" long ground wire to the copper foil with a ring lug going to a screw that was already in the internal aluminum framework of the headlight assembly. I put it all back together and it was better, but still some FM interference... from the other headlight... I surmised. Turning the headlights on and off, you could still hear the interference, but less of it.
    So, I removed and disconnected the other headlight assy ( 5 minute job, now). Started the car, turned on the FM, turned the headlights on and off, and tried several stations. The interference is gone!! Yea!
    The un-fixed headlight is still out and I will put copper foil around it tomorrow, with a soldered-on ground wire, but no ferrite donuts. After I re-install that, I will let you know if the interference is indeed 100% gone.
    A funny note to add. I was talking to a friend a while back ( a know it all friend, ha, ha) about the FM interference, and he said, naw, you probably don't need to ground the copper shielding. I honestly knew better, but for some reason I didn't take the extra 10 minutes to solder on a shield ground wire when I put the foil on originally. Trust your instincts, LOL.
    Lloyd
    SFO, audiodave, davefmy and 1 other person like this.
  13. audiodave
    800
    272
    US
    That's great news! Guess the noise had to go somewhere and a ground handled that! I'm thinking newer more expensive systems should handle this issue. But it's great you took care of yours for so cheaply. Maybe message seller you bought from. Lol
  14. Lloyd-ss
    Lloyd-ss Member
    89
    89
    Ivy, VA
    Four Touring
    I put the copper foil RFI shielding on the DC to DC convertor of the other headlight today. The thin copper foil is wrapped around most of the power circuit and a ground wire goes from the copper foil to an existing screw on the solenoid coil that has "22" stamped on it. Here are before and after pics. I soldered the ground lead to the foil and also soldered the laps in the foil here and there just to hold it together a little better. It looks a bit amateurism, and it is, but it seems to work. It all kind of folds up and fits totally inside the headlight, along with all of the original wiring.
    The end result is good, but not perfect. On strong FM stations, the interference appears to be gone. On weak FM stations, that already had a little bit of their own interference, the LED conversion added a little bit more interference. The DC to DC convertor probably has a noisy oscillator in its circuitry. A more through shielding job probably would have eliminated all of the interference.
    So overall, I am pretty happy with the LED headlight conversion.
    Lloyd-ss
    SFO, orlywon and audiodave like this.
  15. john roy
    john roy Junior Member
    Thanks for the write up and doing the heavy lifting here. The HID's in my 2005 have been ok, but seem to go when there's weather changes getting hot or cold. My passenger one is on the way out now.
    Reached out to the eBay seller to see if they still stock this model. If they do will most likely order and try this swap. I have a spare Phillips bulb, but those are like $90 CDN and it would be nice to have all exterior and interior lights on LED.
  16. audiodave
    800
    272
    US
    Philips bulbs are cheaper on eBay if you search a little. I usex some Deoxit on the connections as well. Seems to be a connection issue. But otherwise go with the LED's! I will when my bulbs show issues. There are companies making these now that cost just over a 100. I would think the noise and fm issue have been fixed.
    SFO and Lloyd-ss like this.
  17. Lloyd-ss
    Lloyd-ss Member
    89
    89
    Ivy, VA
    Four Touring
    Aside from having to deal with the FM radio interference problem, I'd say the swap was a 100% success, and I am glad it is encouraging others to give it a try, too.
    It seems like the cheap DC to DC voltage convertors/power supplies that have an oscillator in them all put out some sort of noise. I just bought a cheap DC to DC step up convertor (on ebay for about $7) for another project. This was for power into a little audio amp circuit and I bet I tried 15 different ways to eliminate the hum it introduced. I finally stumbled into a pair of current limiting resistors on the out put of the convertor with a 330uF cap across the output. But it only killed the noise if the cap was AFTER the resistors, not before them, and the cap by itself did nothing. I am a total novice at this stuff and some smart electronic person knows why the solution worked.
    Lloyd-ss
    greasemonkey007, SFO and audiodave like this.
  18. greasemonkey007
    287
    106
    Thanks again. I've got an 09 now that someone added led fog lights to. Same noise when you turn the fm radio on. Looks like I'll have to give it a shot now!
  19. Lloyd-ss
    Lloyd-ss Member
    89
    89
    Ivy, VA
    Four Touring
    Grease, For starters, you might try just wrapping the little power supply for the fog lamps (assuming they have one) up with some kitchen tin foil and see if that makes any difference. Probably wrap a bare copper wire around it and run it to a ground screw.
    For the copper foil, I had some really light gauge copper flashing that had a glued-on paper backing. I scraped off as much of the paper and glue as I could, and it worked, and was plenty solderable.
    SFO likes this.
  20. Dagmar
    Dagmar New Member
    Portland Oregon
    You folks are great! My 2006 has been theough countless HID bulbs over the years, enough swaps such that the driver side metal retainer clip popped off and fell into the void, never to be found. It may have stuck in a shroud... Anyway, my question is whether the metal bulb retainer spring is still need when doing the LED option. If so, looks like a trip to the junk yard (Toyota wants $300+ for an entire headlamp assembly, not willing to sell a $2 spring). Thanks for any feedback.
