High Beams not working - 2006 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dmax5705, Mar 7, 2008.
  1. dmax5705
    dmax5705 New Member
    recently purchased a used 2006 Prius and now realize the high beams do no work. This is a single bulb headlight and it looks like there is some cover that perhaps is suppose to turn for high beam(?). It does not but I do hear a click when I flick the high beam switch from inside the car cabin. I looked at the backside of the headlamp wiring and I see three terminals coming out of the headlamp but only 2 are wired up. I did not notice any other connections but it is difficult to see.
    this is a salvaged title car and am looking to fix it myself or at least understand whats wrong before I take it to a shop.
    Appreciate any help. thanks.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Do you have HID headlamps? The HIDs are attached to a ballast unit. From your description I suspect you do. With HIDs, there is only one bulb for high and low; a little shutter moves into place for the low position. If the shutter has failed on both sides, I suspect a wiring or controller issue, as it would be unlikely to have two fail at the same time.
    Tom
  3. dmax5705
    dmax5705 New Member
    These don't appear to be HID. Based on what I can find on the internet the terminals coming out the back correspond to non-HID bulbs for the Prius.
    2004 - 2007 Toyota Prius Headlight Bulb
    top picture looks like what I have.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Do you have fog lamps on the car? If you do, then your headlights are HID. If not, then they are halogen bulbs.
  5. dmax5705
    dmax5705 New Member
    yes I do have fog lights. The wiring I see by whoever did it appears to go from the fuse box area directly to the lightbulb itself.
    Does this sound right for a prius with hid lights? I looked under the hood of a friends prius but am unable to
    see anything as he has a cap that covers up the back of the fixture.
  6. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    if you have HIDs, there is a little yellow warning sticker above each light housing under the hood.
