High consumption
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tariq87, Apr 23, 2018.
  1. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Dears i need your help because my car 2010 (155000 KM)
    Consume 20 litres each 300 KM
    Even i changed the PCV valve and clean the air filter and clean EGR pipe and changed the oil to (10W -30 ) and changed spark plugs ..
    What else should i check to ensure best consumption with it..thanks in advance..
  2. Simonak
    Simonak Member
    Changing oil to 10-30 will will hurt the fuel consumption a little not improve it.
    If my calculation are correct 35mpg its kinda bad even myself during winter I can do like 43MPG.
    Might be your traction battery getting old and doesn't hold charge well.
    You can test it just by looking at the battery bars when they are full try just to use battery mode and see how long they last.
  3. Tariq87
    Tariq87 Member
    87
    28
    jordan
    And I also felt that the oil was heavy on the motor ..regarding to testing battery...
    It's depending on road conditions and using AC .. how should i test it will..To know if its old or not..?or there is other reasons...
    Thanks in advance
  4. Simonak
    Simonak Member
    When engine is hot and you have full bars the EV mode should have range of 1.25 mile or 2km I think but I never test like this.
  5. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    install an oil catch can
  6. Mendel Leisk
    42,272
    Just to state the obvious, assume it's gasoline we're talking about. Yeah, that translates to 6.7 liters per 100 km, and 35 miles per gallon (US). That is well above the median but not unheard of. Fuelly stats for 2010:
    For a bit more info: what kind of driving? High speed, short trips, constant AC use could all contribute to high gas consumption.
    Also, any recent rear brake job? Misassemble of the rear brakes can cause drag; you could feel the wheels after an extended drive, see if any feel hot. Normally they would only be very slightly warm, at most.
    Is this a recent change in fuel consumption, it was better in past?
    I wouldn't call 10W30 too heavy of an oil, for Jordan.
    #6 Mendel Leisk, Apr 23, 2018
  7. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Please help me with more details about oil catch can..what is it ?
  8. Simonak
    Simonak Member
    This have nothing to do with fuel consumption. I did all cleaning of EGR intake manifold install new spark plugs and Oil catch can but my MPG stay almost the same.
    Only difference I noticed is silky smooth engine specially in cold mornings.
    But checking brakes is a good idea specialy if you have cold salty winters. Check specialy rear brakes pads if they are wearing even because those guide pins tend to stuck.
  9. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    #9 scona, Apr 23, 2018
  10. 4md
    4md Member
    97
    55
    Sofia, BG
    20l per 300km means 6.67/100 (35 mpg). It's not too high and I don't think the engine is worn out. Test the oxygen (lambda), MAF and temperature sensors if they give correct data and if the oxygen sensor reacts quickly. Yup, the voltage MUST change VERY quickly.
  11. Simonak
    Simonak Member
    Or might be something small as tire pressure or bad alignment. Try get front 40psi and 38psi back. In Europe might be 2.75bar front 2.62 back.
  12. bisco
    52,785
    could be a weak hybrid battery from the heat, check the 12v health and cabin filter.
    are you running LRR tires?
  13. Tariq87
    Tariq87 Member
    87
    28
    jordan
    My type of driving is some how normal speed because most of it in city.. but i kicked down the throttle in take off many times..and i use AC constantly because of high temperatures..and no recent rear brake change..this all of it
  14. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Thanks for replying...
    Im asking for more details because i want to change it ..i drove more than 15000 KM
    So its time to change it...
    If you hanve any videos or PDF how to do it you will help me..
  15. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Thanks you for replying...question please..what do you mean by voltage and it must be change?
    And if you have video how to do it or PDF it will be very help full..thanks in advance
  16. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Sure i will check it ..thanks
  17. Simonak
    Simonak Member
    For EGR cleaning watch
    For Oil catch can you can check this forum posts Oil Catch Can, Eliminate that knock! | PriusChat
  18. Mendel Leisk
    42,272
    Still, check by feeling the wheels after a drive, looking for any that are markedly hotter, which would indicate dragging brakes.
  19. 4md
    4md Member
    97
    55
    Sofia, BG
    Connect an OBD adapter and check the live data (parameters) of those sensors. The O2 sensor gives voltage in range 0-1 volts OR 2-4 (0-5) volts, but I doubt the Prius uses wideband sensor. When the sensor is hot enough, it's output must change quickly, this means it works fast enough (it's critical to the correct air-fuel mixture ratio). There are a lot of youtube videos about O2 sensors and how to test them.
