High EMF in rear right seat?
Discussion in 'Gen 3 Prius Main Forum' started by summit123, Oct 26, 2010.
  1. fuzzy1
    10,710
    At least you contributed mightily to my Profit Sharing payout, back in the days when it existed.
    It was probably someone noticing that the Tri Field Meter did a good enough job, at 0.1% of the cost, that caused company profits to collapse, leading in domino fashion to the entire Dot Com Bust.
  2. bwilson4web
    16,537
    What is the level of the cosmic background radiation?
    I've long wondered if we could make a spaceship powered by cosmic background radiation:
    • 160.2 Ghz - 1.9 mm wavelength
    • everywhere
    So what we do is equip the spacecraft with 0.8 mm, highly conductive, antenna with a full-wave, rectifier between each leg. The subsequent, DC power collects in ultra capacitors and is used to power a highly efficient, super-conductor magnet, cyclotron or linear accelerator. The front of the craft presents a magnetic trap to capture the dust and hydrogen atoms needed for fuel.
    The reason we can't power our Prius by the EMI/EMF of cosmic background radiation is atmospheric attenuation. But in space, no problem.
    Like the farmer who took the power driving the internet video florescent tubes, maybe it is time to think 'out side the box.' Time to design a stellar system, 'star' drive, the 'impulse power', to reach our nearest neighbors. <grins>
    So what say you, our EMI/EMF friends, how about running on cosmic background radiation . . . God's power lines?
  3. Navi05
    Navi05 New Member
    Maybe all the energy radiated could be redirected back into charging the battery system somehow. It moves the needle on my EMF meter but Im not sure if thats caused by the 9 volt in the meter or the radiation forcing the internals to move. I think a system that converts vibration or hydraulic shock into electrical energy would work better though.
    Hydraulic shocks in big rigs have been built that convert that pressure force into usable electricity. We're surrounded by great opportunities to use energy efficiently. As I type this I've just remembered 3 different possible MPG boosters which I'm sure have already been implemented or tested by someone out ther
  4. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Bob,
    Unless I'm grossly mistaken, I think that this idea gets hit by thermodynamics. In thermo, useful work is only performed by moving energy from a higher temperature environment to a lower temperature. That's kind of how the ICE motor works: hot combustion products expand, cooling down, the exhaust goes out the tailpipe, and the difference in energy between the high temperature compressed stuff and the low energy uncompressed gas is what's converted into useful work, i.e., moving the pistons and the car around.
    The problem with that background radiation is, well, it's background radiation. Generally speaking, you can't find anything in the local environment that's cooler than the background radiation. That includes things like, say, Pluto. If you can't get dump the energy in a cooler place, then you can't make useful Work, in the Physics sense.
    There are places in the universe that have lower temperatures than the background; massive black holes, for one. (Yes, black holes have a temperature: See A Brief History of Time, by S. Hawking.) So, if one had a machine in close vicinity to such a hole, then radiation could be taken in in the "up" direction, radiated out the "down" direction, and useful work performed. Until, of course, since the universe is cooling as it expands (assuming no Big Rip, of course) its temperature will eventually drops below that of the black hole. I suppose one could then reverse the antennas on the orbiting machine and run things the other way until the black hole evaporates..
    Of course, in the local neighborhood, there's a nice, energetic source of heat that's much hotter than the background: the sun. And we know how to absorb energy at the peak solar luminescence point: Solar cells. (Plants have kind of figured this one out, too, natch.). And we have a place to dump the energy into as we move it from the sun to elsewhere, that being the local environment, which is a wee bit cooler than the sun. In space, that translates to everywhere that's, well, black.
    I guess another way to put it, and it's a pretty close analogy, it to consider water in a river. If said river is above sea level one can extract energy from the water by putting it over a dam or under a waterwheel. But, as a first order issue, putting a water wheel or dam in the middle of the ocean doesn't do one much good, funny business with tides and ocean waves not considered.
    Regards,
    Kbeck.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    I don't imagine that Bob was serious. I'm pretty sure he's having fun with some of the hair-brained ideas kicked around on this and other similar threads. Obviously, without a energy differential, work is impossible.
    Tom
  6. bwilson4web
    16,537
    Not on the Internet! Where all the women are strong, all the men are good looking, and all the children are above average. <grins>
    Squashed Writers - A Voyage to the Moon by Cyrano de Bergerac - condensed and abridged
    It was just a brief introduction to quantum thermodynamics . . . a place where particles and anti-particles can emerge out of nothingness and black holes evaporate from Hawking radiation. You know, Schrodinger's steam engine.
  7. landstander
    landstander darling no baka
    108
    A place where the nuts hunt the squirrels
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The key point - IT'S A MAN BABY!
  9. Navi05
    Navi05 New Member
    I've measured the EMF of my active cell phone and it's below 0.3 milligauss, but I think I just lucked out with my samsung. I should test others.
    Would someone know a creative way to shield almost all of the cables running through the cabin? What could the negative affects be if I did this? All I can think of is less radio static and lower EMF as the positives. I've stripped my auto of carpeting and plastic trim and she's ready for experiments. Would anyone recommend flexible steel conduit for EMF reduction on cables? I would use that first then a possibly a few layers of spiraled (@) mumetal or (( o )) <==center is cable bundle within flex-steel conduit.
    http://img.diytrade.com/cdimg/51524...eel_flexible_Conduit_for_cable_protection.jpg
    These cables are showing anywhere from 30- 90+ milligauss on my meter and I know my Trifield meter isn't balanced for all the HZ possiblities of the prius, but even IF it is just off its waaay too high. I've managed to lower the EMF 87.5 percent from 90 to 10 or so, but its waaay too bulky with the sheet metal that I crudely placed for experimentation.
    I kinda like how my prius is at the moment without all the carpeting as I feel I can access and test its inner workings in a flash.
    Oh, and I'm pretty sure I've also got a dead battery blower fan and a metallic box below the emergency brake line that may have gotten some coffee spilled on it. I hope cleaning that will fix the ABS (!) and brake light issue on it but I highly doubt it.
  10. Former Member 68813
    3,524
    983
    US
    Interesting. Like Bob said, we need pictures of undressed prius.
    How do you know the battery fan is dead?
  11. Blizzard10
    Blizzard10 New Member
    168
    38
    Queens, NYC
    Is there a way to hide a thread. I can't take this any more
  12. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Washington State, (Near Portland)
    If you can't accept the fact that this thread might go on until the Internet dies, then maybe you should try drugs and alcohol.. - It has done wonders for me.....
    As I stated earlier:
    Keith :)
  13. qbee42
    18,058
    3,081
    Northern Michigan
    For any of this to be meaningful, you are going to need a real meter. Rolling dice or reading chicken entrails will produce data on a par with the TriField meter.
    Tom
  14. dogfriend
    7,512
    1,191
    Carmichael, CA
    Tin foil. Lots and lots of tin foil. :madgrin:
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Tsk tsk tsk
    DC power cables .....
    Maybe you are picking up ghosts
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    I would recommend the entrails
  17. fuzzy1
    10,710
    (1) Where did you find a cell phone that operates within the 100kHz frequency limit of the magnetic field sensor of your Trifield meter?
    (2) Trifield notes: "*Sensitivity is inversely proportional to frequency from 2K Hz to 100K Hz". What adjustment factor did you apply?
    I'm not sure how your measurement is any better than asking the nearest 90 year old nursing home resident to gauge dog whistle loudness. Maybe soaking the chicken entrails in whiskey will help reveal the answer.
  18. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    If you stitch chicken livers into dodecahedrons and place 1 on each major ECU of the vehicle, it will act as an EMF absorption module. This is similar to the bio neural gel packs of the Enterprise NCC-74656.
    They will eventually fill up and will require replacement. I get about 200 hours of drive time per liver-dodecahedron. I have heard that if you make a turducken based geometric absorption module, they can last much longer but I have not tried it. Since installing these modules I continue to never get headaches or any other illness. Therefore it is very conclusive that they are doing their intended purpose and blocking all EMF.
  19. Former Member 68813
    3,524
    983
    US
    I'm new to this discussion, but went to the Trifield® Meter and saw: Accuracy @ 60 Hz (50 Hz): +/- 20% of reading
    Am I missing something?
  20. Former Member 68813
    3,524
    983
    US
    If you are so smart, how come you did not see this 4 lines below: Frequency Range: 50 MHz – 3000 MHz (3 GHz)
    Apparently there is more than one range, doh.
