High engine RPM going downhill
Discussion in 'Gen 3 Prius Technical Discussion' started by nedim, Jan 9, 2015.
  1. GregP507
    GregP507 Senior Member
    3,002
    481
    I've never had that happen, even pulling a 6000 lb trailer. In fact it has a "trailer" button which provides more transmission-braking.
  2. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I did and fortunately I had the oil changed right shortly after with no damage done.........lesson learned.
  3. GregP507
    3,002
    481
    I remember the old Desi@Lucy movie called The Long, Long Trailer. They were pulling a giant Airstream through the Sierra Nevadas with a convertible as I recall, and I think I remember a scene when Desi had his foot to the floor as they crawled all the way up a long hill at a walking pace.
    I wonder how many transmissions they burned out shooting that scene.
  4. GregP507
    3,002
    481
    Correction: It wasn't an Airstream.
  5. fuzzy1
    10,690
    Your dad was talking about replacing worn brakes, not handling a downhill situation where the brakes have overheated and lost their effectiveness.
    B mode is there for situations that have a risk of overheated brakes. If you are still using a bit of throttle here and there, then you are far from that situation.
  6. CR94
    CR94 Senior Member
    2,823
    1,238
    Northwestern S.C.
    Even if there are no faulty parts, water vapor from the atmosphere slowly permeates through seals and hoses into the fluid.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    One answer to 'why is there a B mode?' is that in the US, regulations require a gear position with more resistance than D. B mode satisfied the regulators. While it can be used well by a driver, you never need to use B.
  8. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Fuzzy1 , I. Only add a bit of throttle when I want to extend the glide. H
  9. fuzzy1
    10,690
    If you are extending a glide, then there is no imminent risk of overheating the brakes, so it is not the situation that 'B' is meant to address.
    CR94 likes this.
  10. GregP507
    3,002
    481
    No, "B" doesn't stand for "Back-up."
  11. HaroldW
    716
    95
  12. Qamar Fahim Khan
    Qamar Fahim Khan New Member
    25
    Lahore, Pakistan
    Recently i visited hill station, here one of the track is very steep and rough, on uphill it was ok but on downhill i engaged b mode but still speed was way fast due to steep, my question is how to control speed on such steep hills, i miss first gear of manual in these hills, please help
  13. bisco
    52,804
    b mode and brakes. have you considered a funny car parachute?
  14. Mendel Leisk
    42,299
    In case you haven’t heard the expression; this is a funny car. ;)
