High frequency pitch sound
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Electric Charge, Sep 24, 2012.
  1. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    When I test drive the PIP, I kept hearing a high frequency pitch noise whenever the car was accelerating. It almost sounds like when you lightly touch the trigger on a cordless drill. Sales guy and my wife couldn't hear it, but I do have extremely sensitive hearing.
    A quick search didn't reveal anything, so I am wondering if this is a problem, or maybe part of the pedestrian warning system (although it happens at higher speeds as well). If someone can confirm this before I pick the car up today, that would be great. Thanks :)
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Perfectly normal, pick up the car and enjoy it and the ev driving which comes along with it! Prius and the plug in Prius is going to sound different than a conventional car you may be used to. Things like the inverter, electric motor, and the new pedestrian notification system make noises which at first seem different but are normal.
    52,773
    you must have dog ears.:p
  4. Electric Charge
    545
    133
    Syracuse, NY
    Pretty much, thought for sure it would go away as I get older, but still have my superman hearing :)
    That said, it drove me nuts during the test drive, hopefully I can get used to it.
  5. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    What you are hearing most likely is the inverter. Its basically like a high frequency switching power supply on steroids. These switching supplies "chop" the output signal on and off very fast with high power semiconductors. The ratio of "on" time to "off" time allows a fairly precise control of output power as well as the AC sinewave generation. This is often done at kHz speeds, making it faintly audible. If you listen, you may also hear it during braking as the same thing happens with the regen system driving back through the inverter.
    Here's a description of the basic idea if you're interested.
    TMEIC GE e-news: Drive Time
    Rob
  6. Electric Charge
    545
    133
    Syracuse, NY
    Makes a lot of sense, thanks for confirming!
  7. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Yeah Ive heard it during breaking. If Im walking down the sidewalk and I hear the sound I always know there is a hybrid approaching.
    SJ PiP likes this.
  8. Jimbo69ny
    712
    107
    Ithaca, NY
    What I really hate is that god awful racket that comes from the front part of the car. Im not sure what it is but its in front of the dashboard and under the hood. God! I hate when I hear that sound!
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    remove it:D
  10. Chris11
    Chris11 Member
    220
    Washington
    I sit in my garage with driver's side window down and I can immediately hear a high pitched sound when I put it in reverse and let off the brake. Put the brake pedal down again and it goes away. Let off the brake and it comes back.
    I think it's the electric motor ...but I don't know why it would make noises with the brake off yet not moving.
  11. MikeyF
    MikeyF New Member
    Isn't this the intentional sound put into all 2012 model years to give pedestrians the sound of something approaching?
  12. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    It sounds like you're hearing the pedestrian warning system. Its especially loud when sitting in the garage with the window down. It should go away past 15MPH or so. Although somewhere around 10MPH, I cant really hear it anymore while inside the car.
    This can be disconnected, removed, etc. There are instructions here somewhere. IIRC, Rebound had a nice walk-through with pictures.
  13. Chris11
    Chris11 Member
    220
    Washington
  14. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    What I meant was, the sound is present from 0-15MPH. And yes, the pedestrian warning system only makes a noise when your foot is off the brake. When your foot is on the brake, presumably while you're at 0 MPH in the garage, the noise goes away.
    here's a video of it:
    SJ PiP likes this.
  15. Chris11
    Chris11 Member
    220
    Washington
    Ahh...thanks for that explanation. That makes sense.
    I can't see any URL for a video. I've noticed before when people say "Heres a link, etc." I can't see it. Stupid computer ...of course it's not stupid operator.:)
  16. SJ PiP
    SJ PiP Member
    190
    35
    so that explains the loud whirls... never heard on my stealthy first gen Highlander hybrid.
    maybe this pedestrian warning switching on and off explains that faint click I hear when the brake pedal is depressed at slow speeds (no radio or ambient noise in the cabin of course)?
  17. Dana Sion
    Dana Sion New Member
    Hudson, New Hampshire
    Personally I feel it's best to leave the speaker hooked up, I don't want to see a white Prius turn "red".
  18. bisco
    52,773
  19. terpsmandan
    terpsmandan Member
    144
    That's what I thought because mine does not make any noise when standing still in EV but makes a Jetson like noise when it starts moving at low speeds.
  20. Adam Leibovitch
    498
    102
    There is another high pitch noise besides the pedestrian warning. And a drill is a great example, because mechanically its very similar. An electric motor spinning an axel.
