High Mileage Prii Being Sold on E-Bay Motors
Discussion in 'Gen 2 Prius Main Forum' started by mhawkin1, Aug 2, 2007.
  1. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I'm one of the few that had a HV battery replacement on my '01 Prius (83,400 miles under warranty). The DTC that caused the replacement were P3006 and P3000. Couple of worthwhile notes:
    1) Just a beep and the Triangle of Death appeared, along with the exclamation in the car symbol on the MFD. The Main Battery Symbol did NOT light. I find that interesting.
    2) The car continued to run and operated fine for a couple more days before I got it to the dealer. This was not driving all around, just minimal, conservative driving to get all passengers home and backup car in place. (I had seen the TOD a couple of time before, so now I realized that if the car could be driven to the dealer if it was still working fine.)
    3) There was only a minor MPG increase (~ 1 MPG) after replacement that could easily be due to the phase of the moon. I was hoping for a whopping increase....but not to be.
    4) Most of all. What a good deal. Two previous Camry's had small engine block cracks (after a very long life) and that is not news worthy to the outside world, it's a Prius battery failing at 150,000 miles that stops the presses.
  2. mhawkin1
    mhawkin1 Matt
    102
    Indianapolis
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Aug 3 2007, 06:13 PM) [snapback]490185[/snapback]</div>
    Or, 83k in your case.
  3. Elephanthead
    Elephanthead Junior Member
    72
    Who keeps a car for more then 8 years anyway? Especially in Indy your either going to get run into by some crazed soccer mom or crack head, or the road salt is going to eat the car away.
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    <div class='quotetop'>QUOTE(Elephanthead @ Aug 3 2007, 05:42 PM) [snapback]490239[/snapback]</div>
    I do. In California rust is not an issue, although soccer moms can be. Crack heads are usually on foot.
    We sold our 93 Toyota truck in June and it didn't have a spot of rust on it. It is not uncommon to see cars and trucks from the 50's and 60's still used as daily drivers.
  5. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    There was a man who came to Hybrid Fest this year that had 300K+ on his Prius1 that still had the original battery in it.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(Elephanthead @ Aug 3 2007, 08:42 PM) [snapback]490239[/snapback]</div>
    Me. 1983 Delta 88 replaced with 2000 Intrigue. 1989 Delta 88 replaced with 2006 Prius. 1975 LeMans lasted only 8 years.
  7. naterprius
    naterprius Senior Member
    1,843
    For the record, the original Prius (up to 03) was never purported to have a "lifetime" battery. The new Prius, 04 and up, is.
    Or in my case, 29,000 miles. ;-)
    Nate
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I second dogfriend. I sold my 91 Camry V6 in early 2002. It was my mom's car most of the time and was in Cali originally and then spent almost 5 years w/me in WA state. My mom still drives a 96 Camry.
    We have no rust probs at all.
  9. mhawkin1
    mhawkin1 Matt
    102
    Indianapolis
  10. wiiprii
    wiiprii New Member
    148
    <div class='quotetop'>QUOTE(mhawkin1 @ Aug 23 2007, 10:18 AM) [snapback]501065[/snapback]</div>
    I like how they lifted their description from another auction or website (this being a 2003 model there is no hatchback):
    In most other ways, the Toyota Prius functions like a regular family car. The interior is comfortable for four adults and comes standard with most modern convenience features. On the Prius's dash, there's an information display that can be used to show the operational status of the hybrid system. The vehicle's hatchback design provides extra versatility in terms of carrying items, and the rear seat can be lowered flat.
  11. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(mhawkin1 @ Aug 23 2007, 12:18 PM) [snapback]501065[/snapback]</div>
    I admit you've got quite a series going there. Would like to know what the actual percentage of 1G Prii are that required HV battery replacement a)under 100k miles, and B) over 100k miles, and c)how many exceeded 150k without evidence of battery problems at all.
  12. dogfriend
    7,512
    1,190
    Carmichael, CA
    <div class='quotetop'>QUOTE(wiiprii @ Aug 23 2007, 10:37 AM) [snapback]501077[/snapback]</div>
    Yes, I noticed that some of the other details (such as EPA mpg) were for the 2nd gen Prius. Of course, since the seller is a used car dealer, I wouldn't believe anything in the posting without other documentation to verify it.
  13. KTPhil
    KTPhil Active Member
    1,379
    22
    mhawkin1, please pay close attention to hobbit's words:
    "Please remember that most '01 - '03 Classics were subject to the TSB
    about the battery bus-bar contacts and leakage/resealing work. After
    a while Toyota took to simply replacing packs wholesale rather than
    having techs dig in there and romp around with the high voltage,
    which would likely count as "battery replacement". That's probably
    still going on, given that the battery is one of the 8/100K warranted
    items, and the TSB happened because of a manufacturing defect allowing
    the battery module terminals to start growing a little corrosion."
    This is the likely cause of the replacement--a known defect repaired free by Toyota, NOT a wearout issue.
  14. mhawkin1
    mhawkin1 Matt
    102
    Indianapolis
    and another one.....:)
    I understand KTPhil - my only point is wow - I have not seen a Prius with its original battery post 150k. Hopefully when the 04'-08' models reach 150k they will still be perfectly fine.
    and the 'who wants to drive a car for 8 years anyway' is a LAME argument at best.
    http://cgi.ebay.com/ebaymotors/2001-Toyota...1QQcmdZViewItem
  15. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(mhawkin1 @ Sep 25 2007, 08:43 AM) [snapback]517362[/snapback]</div>
    I don't think this one can count in your series:
    Car was rear ended in 2001, repairs were made, I got a new bumper, battery pack (replaced at 100,000 miles - which related to when it was rear ended)
    He clearly states this was related to being rear-ended, not due to battery failure.
    Remember also, that there may be some selection bias whereas those who've experienced a battery failure may be more likely to sell their cars than those who've had no problems and continue to enjoy them.
