high milidge or not 2010 prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mylin, Dec 5, 2012.
  1. mylin
    mylin New Member
    2010 prius
    63,000 miles ( mainly high way miles from oddessa mo to kansas city)
    full maintanance
    overal still in perfect condition
    my grama owns it, and shes thinking its high milidge.. i think its still low but id figure
    id check around and see if theres any proublums with these that we should keep eye out for
    or if its good for another 60,000 miles she only drives it in economie mood
    im sorry if im in the wrong thread im new
    MandyTee likes this.
  2. MandyTee
    MandyTee 2012 Prius Three ~ Classic Silver Metallic
    49
    16
    Greater ChicagoLand, IL
    Welcome! :)
    I'm no mechanic, but I would say unless she is having any specific issues, you should be good to go for many many more miles.
    mylin likes this.
  3. mylin
    mylin New Member
    ( thanks for your time and the in put )
  4. MandyTee
    49
    16
    TsKarma likes this.
  5. TsKarma
    TsKarma Junior Member
    82
    Ditto to MandyTee. My 2010 has 81k miles with no major issues. I only had a MAF error via the check engine light a few weeks ago. Solved it by buying an MAF cleaner and spray the MAF after I removed it.
    mylin likes this.
  6. mylin
    mylin New Member
    just a thought, after reading other post have you ever had bolts come out or losen up? my brother in law had a suspinsion bolt come out on hes toyata yaris 4dr and another post on her wuz saying your exposta torqe every thing down brakes, suspinsion, body panels ect that kinda scares me id think they company should invest in some lock tight
  7. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    "Milidge.....suspinsion.....losen.....Toyata.......exposta.....torqe"........you should invest in learning about spelling, grammar.....AND.....the English language........!!!
  8. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    And some of us should keep their comments to themselves. A man's worth has little to do with his ability to spell.
  9. fuzzy1
    10,706
    When grandma was a spring chicken, that was high mileage. But cars have improved greatly since then. I budget my modern cars to last at least 150,000 miles. My 2010 Prius replaced a 1980s car with 235,000 miles, and the two non-hybrids still in the household are doing well as they close in on 200,000 miles.
  10. MandyTee
    49
    16
    I just assume everyone is typing on a tablet & that accounts for all the errors ;)
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I try to only mention horrible spelling when it confuses the topic: an action that brakes the breaks is different than an action that breaks the brakes. When I get confused, I start being a spelling Nazi.
  12. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    mylin, I had to smile when I read this. Since I'm probably as old as your grandmother, I can remember when 63000 miles was considered high mileage. Many cars required major engine work before that many miles. Obviously, you understand that is no longer the case. This car sounds like it has the potential for many thousands of miles more. As others have stated, 200,000 and even more is becoming commonplace.
  13. cbo111
    cbo111 Junior Member
    Calif
    My 2010 Prius just rolled 95,000 miles. Almost zero maintenance problems. One burned out low beam headlight cost me $25 to fix. I do my own oil changes, etc. Great car, should do another 90,000 easy!
    cbo
