High Pitched Noise when accelerating
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Norry, Mar 8, 2025.
  1. Norry
    Norry Junior Member
    United Kingdom
    Last year I had an issue where the whole engine was shaking in drive, the only way it would stop was if it moved to neutral or if I was accelerating very fast.
    Took it to the garage and they said it needs a new damper plate (EGR had been replaced 2 years prior).
    After getting it back I noticed that there was now a loud noise coming from somewhere when I was driving over 40mph.
    I then noticed the CEL come on and I scanned it with one of those readers from Amazon which gave a fault code to do with the fuel pump. I cleared the code to understand if it would come back, it didn't.
    At the time I couldn't afford to go back to the garage for another fix. Fast forward a year and this sound is annoying, I've realised that as soon as I go over 30mph I start to notice it.
    Any idea if it could be a fuel pump that needs replacing or could it be another issue?
  2. ChapmanF
    19,017
    Do you have a record of what the actual code was so you can post it here?
  3. Tombukt2
    Tombukt2 Senior Member
    13,857
    2,516
    Durham NC
    You can barely tell a fuel pump's running when it's running well or poorly. Usually the design of these things is it just doesn't do anything You don't even hear the hum from the fuel tank door anymore if you listen to it or any of that
  4. Norry
    Norry Junior Member
    United Kingdom
    Unfortunately I don't. I normally take a photo to keep a record but I assumed that if it was an issue it would appear again.
    However the light has not come back since.
  5. Norry
    Norry Junior Member
    United Kingdom
    I just find my car to be much much louder. Normally on the motorway all I could hear was the slight humming of the engine, now it's like a sound getting heavier as i accelerate.
    The closest noise I've found is on YouTube under:
    " My car makes a humming/mower noise when accelerating" by someone called @eliseolifts
    The cars done over 300k but i don't want to let it go if I can fix it.
  6. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Best thing to do is get the car in Maintenance mode and then use a stethoscope to find the noise.
    A long piece of vinyl tubing can be used as a substitute. Just stick one end in your ear and try not to get it stuck in any pulleys.
    SM-A536V ?
    #6 mjoo, Mar 8, 2025
  7. Mendel Leisk
    42,343
    What’s the miles? Is it using coolant?
