High Temp Light coming on under heavy load
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jon B, Aug 17, 2022.
  1. Jon B
    Jon B New Member
    So Cal
    I have a 2010 Prius with ~185K on it. The engine temp light came on last summer when I was driving up hill at 80mph in 116 degree weather. Rolled the windows down, cranked up the heat, light when off quick. Since then I replaced the EGR value and cooler. I changed the coolant (not inverter) and transaxel fluids. I've had the light come on twice, in much cooler temps, but engine under heavy load (going up mountain roads). What else can I check to make sure I don't blow a head gasket?
  2. Tombukt2
    Tombukt2 Senior Member
    13,837
    2,514
    Durham NC
    The thermostat right behind the electric water pump The water pump like if you can get the Toyota software to connect to your computer you can see if the water pump is turning decent RPMs when it's supposed to it will tell you that. The thermostat could be old and sticking intermittently. When you're running the car and you get it this hot to make the light come on if you whip over to the side of the road make a note of what hoses are hot or not at full temperature with the light on that sensor is thinking you're getting into the overheat range so I would expect hoses to be pressurized and pretty darn warm Make a note of which ones are not make a little diagram take a picture whatever it takes you may have serious vapor lock or water not moving because of air in it or something like that The Gen 3 is a head gasket candidate at some point and it's life usually earlier than later
  3. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    thermostat?
    maybe @ChapmanF has an idea at what temperature the warning light comes on?
  4. ChapmanF
    18,993
    See this thread. There are two engine coolant temperature sensors in Gen 3. The one in the EHRS hose will light the warning light at 248 ℉ (120 ℃). The one in the cylinder head can also light the light, and I haven't personally tested what the trigger temperature is for that one, but I'm assuming it's the same until somebody tells me it isn't.
  5. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    I had this happen to me. In my case it was the water pump. While replacing, went ahead and also replaced the thermostat. Problem solved.
  6. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Have you replaced the brakes? Cause that might cause the ENGINE temperature light to come on.....
    When you push the engine like you did, it WILL run hotter. But it really should not cause the light
    to come on.
    How many miles do you have on it?
    Anytime the ENGINE temperature light comes on, it would be best to check things related to keeping
    the temperature where it should be. Like the fans, water pump, coolant level, hoses, thermostat, etc....
  7. Jon B
    Jon B New Member
    So Cal
    Thanks for the reply. I have roughly 185K on it. I haven't replaced the brakes on it recently. I know the engine will run hotter, but this is a newer issue. Coolant level is good, it was just changed and verified. May look at the fans, water pump, thermostat
  8. Jon B
    Jon B New Member
    So Cal
    Thanks for the reply! I will look at replacing both!
  9. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    Water pump is arguably a maintenance item on these cars so I wouldn't feel bad about throwing a new one in there at that mileage, even if it's not the real problem, which it sure seems like it is. If you go that route, make sure to use an AISIN pump from a reliable source and report back how your old one looks and spins compared to the new.
    If you continue driving the car I suggest taking a proactive approach towards not getting the light to come on.
  10. ASRDogman
    8,055
    4,083
    The brakes were a joke thing...
    Since you said you just changed the coolant, are you 100% possitive you got all the air out?
    Did you have this problem before changing it?
    #10 ASRDogman, Aug 19, 2022
  11. Trishan
    Trishan New Member
    Sri Lanka
    2016 Prius c
    *** Please check the engine coolant pump motor, replace as a complete unit including the thermostat.
  12. Jon B
    Jon B New Member
    So Cal
    Not 100% on the air. The light came on once before changing all the fluids, that was driving to Vegas, up hill @80 in 115° heat
  13. Virgil Orly Dela Pena
    Virgil Orly Dela Pena Junior Member
    Las Vegas Nevada USA
    I live in the same place and im having the same overheating issue. I replaced the water pump, thermostat, and I cleaned the egr and air intake system. It still overheats when im going uphill. Did you ever fix your issue?
  14. douglasjre
    douglasjre Senior Member
    2,249
    751
    Null, NL
    I pull a 4,500lb load at WOT achieving 18mpg at 65mph in Florida and don't overheat
  15. YaroJane
    YaroJane New Member
    San Diego
    I’m having this same problem: my light comes on when I’m driving over mountains (to/from Vegas, going north of LA) and going over 65 mph. I’ve noticed that if I keep the “hybrid system indicator” gauge out of the power mode, and preferably below the halfway line, the light won’t come on. So sometimes I have to slow down to like 30mph. Would love to know what’s causing this and get it fixed, but it doesn’t seem like any of these ideas have solved it for anyone yet?
  16. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    How many miles on your Prius?
    Your engine water pump is going bad!! Replace it ASAP. OEM water pump is preferred.
  17. atg1986
    atg1986 New Member
    colorado
    I have this same issue, did anyone fix this? i replaced the water pump and thermostat with oem parts, and the problem persist, my coolant level doesn't drop, i normally pull over to have my prius cool down, only turns on if i drive to 90 mph or going uphill doing mountain driving
