High voltage across my main battery pack
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ffej4ord, May 13, 2015.
  1. Ffej4ord
    Ffej4ord New Member
    Orlando
    I've replaced my main battery once over the 170k miles on my gen II Prius. I recently had a cell go bad so I bought a used one on eBay.. all seemed good, however, I noticed a few things that seemed puzzling. 1. After dissembling the battery pack and removing the one bad battery, I noticed the voltage seemed to increase across all the batteries. They were sitting at the 7.4 mark at the time of removing the onc bad cell, but after a day of sitting on the bench, I went back and checked the voltage and they all were sitting at 8.2 - 8.4 volts. I'm not sure if I should discharge them, or is this pack just running high - and that's okay. Any thoughts?
