High voltage traction battery - recalibration - fixed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by myPriusAcct, Nov 25, 2020.
  1. myPriusAcct
    myPriusAcct Junior Member
    29
    17
    Some info that might help other Gen 3 owners.
    I almost bought another HV traction battery believing it was weak at 100k miles. There were wild swings in the state of charge and unexplained overshoots below 40% and above 80%. I figured out how to recalibrate the computer which seems to have put it back to normal.
    About 2 years ago I received my car back from a Toyota software update and noticed the traction battery wasn't quite right. I was starting to experience wild swings in the state of charge. This is normally a sign that the battery was weak and about to fail. I was closely monitoring pack voltages and could see state of charge count down in front of my eyes from just sitting parked with the car on. The engine would then kick in to recharge the battery, but the weird thing is after normal driving it would overshoot 60% and hit 80% very quickly and start the engine again to drain the traction battery.
    To fix it, all I did was find a nice gentle hill and glide down it to charge the battery until it reached 80% state of charge. Then I disconnected the 12v auxiliary battery to reset the computers. I then let the car glide further down the hill until it reached 80% again, then reset again.
    For the last 5 months now it seems to be back to normal. Somehow the battery ECU was recalibrated and the whole system is working like new again. Pack voltage delta is back to a healthy 50mv.
    If you have a weak traction battery, try this trick and tell me how you go.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    when 12v is reconnected, do another round of regen to 80%? Wouldn’t regen not charge anymore for the 2nd round of regen since SOC is still 80%?
  3. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    I believe you are on to something and I was thinking the same with a Lithium battery I am testing.
    I was thinking of draining it as far as I could then disconnecting the 12v.
    Since my pack is different it would recalibrate it and show true numbers.
    This is the same as with android phones which come with a set Mah batteries and when you put in an aftermarket battery like "ZeroLemon" you need to calibrate like so.
    Thumbs up to you.
  4. myPriusAcct
    29
    17
    When you disconnect the 12v battery to reset the battery ECU it also resets the state of charge back to 60%. You can then give the pack another 20%.
    State of charge is a combination of coulomb counting and max voltage. After a bit of normal driving it seems to figure out the pack capacity and adjust accordingly.
