High wattage lights and temperature issues.
Discussion in 'Gen 3 Prius Main Forum' started by Ipanemaguy, Dec 13, 2020.
  1. Ipanemaguy
    Ipanemaguy Junior Member
    New york
    2015 Prius v wagon
    A friend gave me some Hella 100w HB3 bulbs and ceramic plug connectors. I am concerned that these bulbs will generate higher temperatures and melt or destroy the headlight housing. Yes I know about legal wattage for auto bulbs.
    What are the pros and cons. Recommendations.
    iPad ?
  2. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    I put some 100s in my wife's subaru; the only thing needed were the ceramic plugs & a higher rated fuse /
    no problems burning the bowl with the higher temperatures /
    if your lights are adjusted correctly there should be no problem with other drivers; in comparison to some led or hid lights the 100s are still way dimmer & more yellowish /
  3. ChapmanF
    17,347
    Original wiring with that higher rated fuse, or did you run new?
  4. StarCaller
    1,271
    723
    harness from the battery with two relays & fuses /
    #4 StarCaller, Dec 13, 2020
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    IF.....the lens or reflectors are plastic.....which I think is highly likely......then I think you have a valid concern.
