High whiney noise while driving.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by simplifying, Sep 8, 2018.
  1. simplifying
    simplifying Junior Member
    33
    Lawrence, Kansas
    My 2006 Prius just starting making a high pitch noise only while driving. Does not make the noise while not moving. It appears to be having no other symptoms. Thanks in advance for any ideas.
  2. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Something thin and tinny rubbing a brake rotor?
    Are any of the brakes hotter then the others?
  3. JC91006
    16,937
    8,647
    Maybe you have a low brake indicator on your pads. It's warning you the brakes are low
    DLC82SV likes this.
  4. audiodave
    audiodave Active Member
    800
    272
    US
    Jack it up, spin the wheel by hand and listen. Might just be the low pad metal tab as JC mentioned.
    DLC82SV likes this.
  5. bisco
    52,880
    wheel bearing? cv joint? inverter?
  6. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    Water pump and/or belt tensioner bearing? OP could be moving forward under battery power to a point before the gas engine kicks in. OP could be stopped and the gas engine does not turn on.
    Where does the sound seem to be originating? Engine compartment? Front R/L/Both, Rear R/L/Both?
    johnjohnchu likes this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    How many miles on car?
    Put the car in inspection mode and engine will run continuously so you can listen to it.
    Oil full.....belt worn.....red specks all over front of engine reflecting leaking and blown water pump.
  8. simplifying
    33
    Lawrence, Kansas
    All fluids are fine. I do not have the ability to hoist it up high. I do note a tire shows being low. Last time the car was in (2017) I was told brakes will need to be done in 2018. Thanks for the responses from you all!
  9. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    Page 329 of the 2006 Owner's Manual:
    Brake pad wear limit indicators
    The brake pad wear limit indicators on
    your disc brakes give a warning noise
    when the brake pads are worn to where
    replacement is required.
    If you hear a squealing or scraping noise
    while driving, have the brake pads
    checked and replaced by your Toyota
    dealer as soon as possible. Expensive rotor
    damage can result if the pads are not
    replaced when necessary.
    DLC82SV, Raytheeagle and Starship16 like this.
  10. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Just started making or just noticed making?
    I'll go with the inverter.
  11. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Michelin Premier tires? :ROFLMAO: (y)
  12. JC91006
    16,937
    8,647
    If the sound is a high pitched sound, it's the brake indicator. If the sound is not high pitched, then it's your tires making the noise
  13. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    I'm having the high pitched whine... pretty loud at 55+ .... stops if you put it in neutral.... inverter board replace by toyota last summer.....got louder ever since......
  14. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    Does it vary in pitch and intensity/volume as speed varies? Any pulsation felt in steering column? Do you hear it more pronounced on sweeping curves? If yes to any of these I would suspect wheel bearings.
  15. bisco
    52,880
    or bad tyres
