Higher viscosity oil for motorway driving
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by drives, Apr 22, 2016.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I don't have a problem with that but what's your logic for the 40 weight? 0W-40 Mobil-1 I put in my minivan and I certainly will use it in my Prius if I need to, but I'd likely blend it a bit. I would not hesitate to try that if I was losing oil or something.
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    being on the WAY safe side /
    the 0w-40 is the only mobil1 which is approved by bmw as a L1 long-life oil/
    (doesn't matter that I change my oil every 5000 miles neway....)
    I have two more cars (forester & a gto), they get filled with the same oil & I never had the slightest problem /
    &, regarding to 'bob-is-the-oil-guy', the mobil1 0w-40 runs rather on the thin side, so it's close to a 0w-30/
    BION
    StarCaller
    m.wynn, orenji and wjtracy like this.
  3. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I know the stuff...I got a 5-qt bottle European Formula 0w-40 Mobil-1 right here filled with drained used oil. It says good things about BMW/VW approved etc. It has A3/B3 rating which is not A1/B1 but I am not sure if the A1/B1 rating can be attained with a "0W"
    orenji likes this.
  4. orenji
    orenji Senior Member
    5,887
    3,490
    Prius has always had Toyota 0W-20 oil.....I just did an oil change with Mobil 1, 0W-30 oil. My Gen III has 63,000 miles, hope this will prevent the oil usage as it reaches higher miles. (y)
  5. orenji
    5,887
    3,490
    I just hit 80k miles. Decided to switch from Mobil 1 0W-30 to Mobil 1 0W-40 motor oil. I have no oil burning at this time. I managed 54 MPG today on my way home from Hybridpit. Based on the approval of Toyota for other regions around the world I feel comfortable with this thicker weight of oil.
    RightOnTime and Raytheeagle like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Good to see you back on an oil thread ;).
    I’m still on 5w-30 but this round tried RedLine:). It’s a bit pricey, but our Prius is running smooth and quiet ;).
    After 6600 miles on this oil change I have only used 10 ounces. Will probably end up changing the oil around 8500 miles as we have a trip to “the happiest place on earth” at months end and I’ll give our Prius a fresh batch of Red Line :).
    Getting 52 mpg running 5w-30 on 90% freeway driving(y).
    m.wynn and orenji like this.
  7. orenji
    5,887
    3,490
    Its been one week of driving, around 500 miles and I am still getting 55 to 60 MPG!!! I have seen no issues using 0W-40 Mobil 1.
    m.wynn, mjoo and Raytheeagle like this.
