highlander vs prius
Discussion in 'Toyota Hybrids and EVs' started by donbright, Sep 14, 2023.
  1. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    Comparing a 2008 Highlander Hybrid with 2007 Prius
    Prius wins -
    Prius - big MFD that shows you energy, MPG as a number, all kinds of stuff
    Highlander - Tiny MFD, doesn't show as much info, doesn't even show the correct arrows when doing a force recharge
    Prius - set the AC temperature and it will automatically run the AC until the car reaches that temp
    Highlander - turn the fan up or down manually like a stone age person who has no modern technology
    Prius - big area under rear cargo bay for stuff
    Highlander - no area under rear cargo bay for stuff
    Prius - 50+ mpg
    Highlander - 25 mpg
    Prius - massive discussion forums, lots of junkyard cars / parts
    Highlander - not many discussions online, not as many junkyard finds
    Prius - stock sound system is actually very good
    Highlander - not that great audio, distortion in speakers, volume + tuning knobs develop cruft after a decade+ requiring cleaning
    Prius - simple out-of-the-way shifter that "just works"
    Highlander - ridiculously huge skewmorphic shift lever designed to imitate something its not. uses up valuable console space. and it will also let you turn the car off while it's in "drive" to the point it can roll away.
    Highlander wins -
    Prius - bottoms out all the time, lose your front shield on a curb, god bless you if you are in snow or dirt
    Highlander - beautiful 8-ish inches of clearance, and the lowest part is the exhaust pipe, can actually do mild offroading though its technically discouraged in the owner's manual
    Prius - weird visibility issues with the huge hatchback pillars and the large a pillars, read window bar thing
    Highlander - actually not bad visibility
    Prius - battery lasts ~ 200k miles
    Highlander - per internet scuttlebut, HV battery lasts longer, perhaps due to the 6 cylinder engine taking more of the workload off the battery more often, or the battery being bigger and having better cooling
    Prius - 2wd
    Highlander - comes with AWD option
    Prius - almost too slow for certain situations
    Highlander - feels like a rocket ship compared to Prius, actually faster than the gasoline-only Highlander
    Prius - no EV button
    Highlander - EV button
    Prius - if you are 6 feet tall and you sit up straight you are basically looking down on the roof - windshield contact area and cannot see anything
    Highlander - if you are 6 feet tall and you sit up straight you can actually kind of see the horizon
    Prius - no 3rd row, 2nd row a lil' short on legroom
    Highlander - 3rd row for small folks, 2nd row can have lots of legroom
    Prius - technically not legal to tow anything
    Highlander - rated for 2000 pounds towing, up to 3500 pounds with sway control device
    Prius - have to open entire hatch to access cargo area
    Highlander - poke a button and the rear window pops open without the whole door popping open
    Prius - manual rear hatch
    Highlander - Power rear door!!
    Overall
    Prius is more quirky and fun for zipping around town, sneaking in little parking spaces.
    Highlander is much better for bigger cargo, more people, worse roads, giant trucks on highways.
    Thanks for coming to my ted talk
  2. hill
    9,041
    We had the very 1st year the Lexus hybrid (virtually same as hybrid Highlander) came out - it would get in the low 30's . But now? Hyhi is Much higher. 36mpg.
    https://www.greencarreports.com/news/1127113_2020-toyota-highlander-hybrid-36-mpg-tops-any-other-three-row-suv-without-a-charge-port"]https://www.greencarreports.com/news/1127113_2020-toyota-highlander-hybrid-36-mpg-tops-any-other-three-row-suv-without-a-charge-port[/url]
    Yes, the older hyhi has improved much - in comparison to the 1½ decade old Prius.
    #2 hill, Sep 14, 2023
