Highway driving
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by rock87, Feb 27, 2014.
  1. rock87
    rock87 New Member
    West Lebanon, NH
    2014 Prius Plug-in
    I noticed in the past few days of driving on the highway that it is difficult to stay up to speed and not be in the power zone. Is this normal? I drive highway to work in Vermont and go up and down hills. I have noticed that sometimes the car gets up to around 70MPH (probably on a decline), but sometimes slows down to around 49MPH! (probably on an incline). I then have to basically put the pedal all the way to the floor and get the engine really going so I can get up to speed. I have no doubt that this is messing with my MPG. I am driving in ECO. Should I be in power mode? Also, do you guys use cruise control? I heard its better to not use it and just try and use the declines in the road to your advantage and try coasting for better mileage. Does this make sense??? Please help. My MPG is only 53! Thanks!!
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah, power mode will give you more ummph. I think power mode changes the software that applies to the gas petal.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    If you want max efficiency, avoid PWR zone. To keep it there even on the inclines, you need to plan ahead. Accelerate before the climb. The speed will decrease when you reach the peak but it wouldn't be that low.
    How are you only getting 53 MPG? Are you charging? How long is your commute?
  4. rock87
    rock87 New Member
    West Lebanon, NH
    2014 Prius Plug-in
    Ok. Ill try that tip. I have a 24 mile commute, and I charge every night. I use EV until I get to the highway, then switch to HV. I then switch back to EV after the high way. I do the same on the way home. Am I supposed to use cruise control to help get better MPG?
  5. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    Check your tire pressure, for best fuel economy inflate the fronts to the max listed on the sidewalls of the tires (either 40 or 44PSI) and the rears to 2 lbs less. Grill blocking helps shorten the gas guzzling ICE warm up time. You might actually save fuel by having the ICE warmed up before you get to the highway.
  6. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    For most people, the answer to that is YES.
    If you have enough mental discipline and enough flexibility in traffic to manually allow it to speed up going downhill and then slow down a bit going uphill you might be able to do a bit better.
    The difference won't be much and most people can't really manage it anyway........because they can't quite get the hang of it or the traffic won't allow it.
  7. fuzzy1
    10,687
    It depends on the hills. But if you want to go with the flow of traffic, without being an obstacle to others, then many hills do require going into this zone.
    I don't believe that this necessarily has all that much impact on overall fuel consumption, especially when using just the first portion of this zone. Fortunately, the Prius ICE efficiency doesn't lose much efficiency for a fair ways into the PWR zone, though some of the additional electric conversion losses in the HSD may start adding up.
    Climbing hills requires more fuel, that is just basic physics. The way you handle downhills has a greater impact on your overall trip MPG. If the terrain is favorable, an efficient downhill style will allow you to recover nearly all that uphill fuel penalty. But some common driving styles will waste it, recovering little. And some terrain will not cooperate with fuel savings, that is a cost of having hills.
  8. rock87
    rock87 New Member
    West Lebanon, NH
    2014 Prius Plug-in
    Easy Rider,
    So are you saying to use the cruise control on straight roads and no to use it on the hilly highway? To let the car speed up downhill and slowdown up hill?
    markabele likes this.
  9. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    CC is not smart to take on hills since it cannot "plan". Do it manually.
  10. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    You said: "I have noticed that sometimes the car gets up to around 70MPH (probably on a decline), but sometimes slows down to around 49MPH! (probably on an incline)."
    Which I don't understand, is the car driving itself? You are, I hope, controlling the car by using the accelerator pedal. What speed are you trying for? If you are using the pedal and avoiding the "PWR" region of the Hybrid System Indicator, HSI the speed variations are simply the results of climbing and descending hills and account for your decent fuel economy. Driving to keep the HSI in the right third of the wide portion, (pulse) or blank (coasting/gliding) will give the best possible fuel economy. Cruise control holds a set speed and wastes fuel with excess power up hills then inefficiently uses regeneration on downhills.
  11. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Try no mode. Push the power button twice. This is no mode or normal.:)h
  12. Easy Rider
    982
    210
    N. Central Florida
    No. Based on what you said in your initial post, I don't think you are a person who can
    control the situation better than the car and it's engineers can.
    I suggest setting the cruise control to keep up with the flow of traffic and just enjoy the ride.
    Like the post before this, I didn't really understand what you were describing in the first place.
    IF......you have the cruise set and your speed STILL varies by 21 MPH......and you are not in
    REALLY steep mountains, then something is drastically wrong with the car.
  13. markabele
    5,084
    1,782
    Nebraska
    Nice guy.
    retired4999 likes this.
  14. rock87
    rock87 New Member
    West Lebanon, NH
    2014 Prius Plug-in
    Is it ok to use the power zone when trying to stay up to speed on the highway? I have been trying to avoid this zone and stay where it says ECO. Could this be my problem?
  15. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    The power zone vs. ECO zone are all relative. The car doesn't suddenly become inefficient when you cross that border.
    Use common sense and do what you need to, to stay at a proper speed in the conditions you drive in.
  16. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    The "PWR" zone of the HSI begins at about 40 HP. Above 40 HP the efficiency of the ICE-CVT system falls rapidly. This translates to dramatic reduction in actual MPG. Even at 40 HP the PRIUS power to weight ratio is far better than a loaded SEMI, but it is worse than some lightly loaded trucks. I'm sure you've noticed some trucks slow down climbing hills, if you need to go faster than a loaded truck it'll cost you some MPG bragging rights and $ while the driver of a loaded semi has no such option.
  17. Easy Rider
    982
    210
    N. Central Florida
    Yes and yes.
    It is impossible to drive the car and never have it go out of the ECO zone on the display.
    Well maybe not impossible but VERY impractical.
    Your first concern when driving should be SAFETY.
    Having your speed suddenly drop 20 MPH is not safe.
    In my opinion, you are putting too much emphasis on economy and not enough on safety and comfort.
    (And I am not trying to insult anybody here; just trying to make sure the point is understood.)
    markrivers likes this.
  18. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    When and where is it unsafe to go a little slower? If my slowing down on major hills causes the HUMMER driver to pass in an unsafe manner is it my fault? I have followed trucks on interstate 75 that slowed from 75 to 35 and had no issue with the safety of their driving. Has anyone ever lost control of a vehicle by going too slow? Many accidents have been caused by loss of control attributed to going too fast. Sure I drive defensively, courteously and economically and even make some accommodations for the aggressive road maniacs but I'm not the unsafe driver, they are!
  19. markabele
    5,084
    1,782
    Nebraska
    I am a total proponent of driving slower. But there is obviously a point where driving too slow relatively to the flow of traffic definitely becomes less and less safe.
    And the question isn't whether it's your fault or not, but whether it's unsafe.
  20. fuzzy1
    10,687
    ... and I believable that the amount of economy loss he is fretting over is surprisingly small.
